lifter adjustment
Old Jan 31, 2010 | 05:29 PM
bubba 40's Avatar
bubba 40
Default lifter adjustment
how do you tell hydros from solids thanks
Old Jan 31, 2010 | 07:44 PM
FLYING's Avatar
FLYING
I think I just answered this on another thread but,if you can see thru the push rod tube you probably are running hydraulic,also inside the lifter assy a hydraulic usually has a wire type retaining clip to keep them from comming apart incase you float one.
Old Feb 5, 2010 | 11:38 PM
09DynaMan's Avatar
09DynaMan
solids generally have the adjuster on the lifter(except when you are running solid converters in a hydraulic unit, where you run a hydraulic style pushrod)
hydraulic have the adjuster on the pushrod
depending on whether or not you are superman, you may(or may not) be able to see this through the pushrod tube
mplecha
Shovelhead
Oct 3, 2017 11:16 PM
swhitinger
Nov 5, 2013 04:27 PM
waynemags
Exhaust System Topics
Jul 14, 2010 10:52 AM
bubba 40
Shovelhead
Feb 10, 2010 10:45 AM
bubba 40
Shovelhead
Feb 8, 2010 11:46 AM
