Speedo Dash Light
Old Mar 14, 2010 | 02:55 PM
mpetrie610's Avatar
mpetrie610
6th Gear
Cool Speedo Dash Light
Hey All:
Got my dash apart / tanks off (internal rust-crud don't ya' know). Anyway, neutral light stayed on constantly, replaced circuit breaker, now all OK, but...
The speedo dash light does not illuminate and I can't remember if it only lights when the bikes running or should it light when I turn the ignition switch on to the "Lights" position/bike not running? Everything else illuminates when in this position with the bike not running.
So, if it's supposed to be on what is the deal? I replaced the bulb, used di-electric grease, can find no shorts, etc. Can the little bulb socket thing go bad?
Please help...
Thanks, Mike
Old Mar 15, 2010 | 07:25 AM
FLYING's Avatar
FLYING
My dash lights only come on with the H-lamp.Check the socket connections as you may have a corrosion issue.
Old Mar 16, 2010 | 05:31 AM
mpetrie610's Avatar
mpetrie610
6th Gear
Hey Flying: Thanks for the response. Like I said, everything else comng off that post of that circuit breaker works as it should. The dash bulb is on a single wire coming off that post. It can only be the socket, right? I swapped out multiple bulbs (that came in a pack), just to be certain it was not a bulb issue. I'll let you know how I make out as I will be buying a new pigtail wth socket today.
Old Mar 16, 2010 | 06:50 AM
Neil74's Avatar
Neil74
If you have access to a multimeter, you can check to see if you have a power problem or a bad ground. Did you remove the dash plate? If you did make sure you have it tightened back down good so it makes a good ground.
Old Mar 16, 2010 | 08:00 PM
mpetrie610's Avatar
mpetrie610
6th Gear
Default Got it!
Hey Guys: Thanks for the advice. I bought a new pigtail with bulb socket ($8.00 from Harley!), and it works fine. Just a bad part...
Vinish
Feb 10, 2025 11:29 AM
KJBennett
2014-2024 Touring Models
Oct 15, 2014 08:02 PM
sixty7flh
Shovelhead
Apr 14, 2014 08:25 AM
pyronuc
EVO
Jun 13, 2013 05:33 AM
Naz_Man
Dec 29, 2008 11:24 PM
