Oil line help needed....
Old Apr 13, 2010 | 02:52 PM
Spades's Avatar
Spades
Default Oil line help needed....
I'm in the process of building my bike...'76 FXE. I took it down to the frame for powdercoating and new paint ect. I did a good job on labeling everything, but one of my tags fell off and I can't find what I need in my service manual. I need to know on the oil pump......the fitting that is on the far rightside....the SMALL fitting. The one that is vertical out of the top of the oil pump. Where does it go???? I took my lines off and lost a tag in the process. I need to run a line from that fitting to where??? Thanks guys......I need the help. It's my first build.
Old Apr 13, 2010 | 03:45 PM
Neil74's Avatar
Neil74
Thats your front chain oiler line to the inner primary.
Old Apr 13, 2010 | 07:05 PM
Spades's Avatar
Spades
Thanks man....I got ya now. There is another small fitting on the pump that has a small fitting also. It's a little lower on the pump on the backside and angled slightly......nothing was ever hooked up to it when I bought the bike. Do you have any idea where that line would go.....from the pump to ?????
Old Apr 14, 2010 | 09:33 PM
SirEagle's Avatar
SirEagle
that would be your rear chain oiler , ties in with the breather on the fitting and will blow oil on the rear chain if you run your breather the right way
Old Apr 16, 2010 | 02:45 PM
RHPAW's Avatar
RHPAW
There should be a fitting bracketed off one of the rear tranny bolts perched over the top of the rear chain. Other end of the hose goes there.
1Fordman
Shovelhead
11
Mar 27, 2017 08:46 PM
Bassin
EVO
Jun 15, 2014 05:45 PM
mattykrupek
Panhead
Jan 24, 2013 10:33 PM
tadams
Panhead
Aug 3, 2009 07:00 PM
tony
Classic
Jun 17, 2005 01:21 AM
