to all the shovelhed guys
Old May 20, 2010 | 12:10 PM
wiksfxr's Avatar
wiksfxr
Default to all the shovelhed guys
did any body to a cam upgrade in your shovel? i have been looking at a few different ones (andrews,woods, crane, ect.).i am looking for feedback before i pick one so plz tell me what you went with and why you picked it.
Old May 20, 2010 | 12:24 PM
FLYING's Avatar
FLYING
I run the Andrews C Grind along with that Dual Plugged,S&S shorty E Carb. The C-Grind is probably the besr cam I have run in a shovel.You can still run Hydraulic lifters and it has a great power curve! Good Luck!
Old May 21, 2010 | 11:53 AM
FilthyLucre's Avatar
FilthyLucre
I have a Andrews "A" in my 72 and an "AB" in the 68. The 68 never overheats now.
Old May 21, 2010 | 03:20 PM
U-234's Avatar
U-234
Andrews, I think a B. Supposed to be a mild cam over stock. Lobes were worn on the stock cam and the shop owner that was doing the work had a slightly used cam for $50. So I got it.
Old May 22, 2010 | 12:21 PM
clb's Avatar
clb
6th Gear
a grind in the 67 runs fine nice manners I can run all day at 8o or hit the twisties on gas an she runs great. ride hard cb
Old May 31, 2010 | 02:06 PM
11sec.shovel's Avatar
11sec.shovel
Default shovel cam
did you mean a bolt in? FWIW. ive had a comp cams .550 in my shovel for 5-6yrs. combined w/ velvetouch lifters. havnt touched 'em since.
Old Jun 2, 2010 | 02:38 PM
RHPAW's Avatar
RHPAW
Sifton 113 (for a heavier FL), with Jim's big-axle hydraulics.
It ain't no speed demon, but can pull out tree stumps, and is very quiet, and starts so quick, you barely hear the starter kick in.
Old Jun 2, 2010 | 05:48 PM
sqdealgeorge's Avatar
sqdealgeorge
A grind Andrews good No head work If you want to get crazy Andrews B grind Gots to do the spring clearance thing Stroke the motor 4 3/4 bore 3 1/2 Dual plug the heads then party on With this bore and stroke you approach 93 CI It's an *** kicker
Teagan
Shovelhead
Jul 17, 2018 02:14 AM
Mac daddy 103
May 8, 2017 05:05 PM
98hotrodfatboy
EVO
Jan 1, 2015 12:46 AM
busterman2
EVO
Nov 26, 2012 09:59 AM
90evo
Dec 25, 2009 06:16 PM
