73 FX From Points to Electronic
Old Apr 21, 2011 | 06:43 AM
98glider's Avatar
98glider
The bike run fine no missing or popping just eratic idle when she gets hot but runs good when I put a load on her. that what brings me to think that the advance weights are sticking or wearing. I am new to points so you have to bear with me on this just trying to get into the points thing here. If I take out the plate first mark it check out the advance to see if okay or move the weights and if I put the plate back in and dont touch anything else to I have to adjust anything like timing or points again Thanks again for your help
Old Apr 21, 2011 | 08:19 AM
d_slat's Avatar
d_slat
Originally Posted by 98glider
do I have to adjust anything like timing or points again
I would. Even if you marked it, who says it's set right? points wear and the opening point will become later as they wear, as the gap will also become less. At the very least check it before and after you take it apart.
Old Apr 21, 2011 | 11:51 PM
nmaineron's Avatar
nmaineron
your going to have to set your timing again which is something that you should learn how to do anyway.Its not difficult.
Old Apr 22, 2011 | 09:36 AM
98glider's Avatar
98glider
Yes I know I am eventually will have to get into there
Old Jul 17, 2011 | 06:25 PM
waukeshajim's Avatar
waukeshajim
6th Gear
Default Electronic Pick Up
I changed the points to Dyna S Dual Fire. DSK6-1 Bike runs great. SOMETIMES I get a cough at idle. My question is should I change the point gap or keep them at stock gap?? I use #4 plugs.
Old Jul 18, 2011 | 01:37 AM
TwiZted Biker's Avatar
TwiZted Biker
??? You don't have points if you have the Dyna S , what did I miss there ? The cough could be bit lean , what carb you running? I think your talking spark plugs not points ? Open your plug gap up a bit with electronic ign you can run up to .045" just depends on your bikes setup and condition . I'll add .005" extra gap and run it for a while no issues add another .005" and try it . If it gets hard to start or you can feel it drop off back .005 to .007 and leave them . Most fall between .040 to .045" .
Old Jul 18, 2011 | 07:32 AM
waukeshajim
6th Gear
I meant plug gap. I'm running a Keihin butterfly. Not sure of the jet size. I'll try widening the gap .005 and make sure the carb is still set a liitle rich and go from there. I will go with a better carb in the future. Thanks!! VJ
83shovl93”strokr
Shovelhead
39
Feb 8, 2019 05:13 PM
reconrabbit
Engine Mechanical Topics
Jan 25, 2018 06:37 AM
waukeshajim
Shovelhead
May 8, 2011 07:55 PM
panicman57
Dec 19, 2010 03:11 PM
johnnyholmes
Jul 24, 2010 07:01 AM
