smoke coming from vented primary
Old May 21, 2012 | 02:43 PM
geos 73's Avatar
geos 73
1st Gear
Default smoke coming from vented primary
My 73 has smoke coming from the vented primary. It is a dry system with a belt drive.Pulled the primary and the belt is ok primary is dry and the smell is not an oil burning smell. The stator and rotor were changed 2 years ago and working fine. The rotor however was very hot to the touch. The bike never shut down. Everything work on the bike. Does anyone think the stator windings may have burnt up. Didn't take an ohm reading on the windings yet. Any ideas would be appreciated.
Old May 21, 2012 | 08:25 PM
TwiZted Biker's Avatar
TwiZted Biker
Do the charging system tests if you don't see or smell any belt junk , about all it could be is stator cooked .
Old May 22, 2012 | 04:31 AM
geos 73's Avatar
geos 73
1st Gear
Thanks, Haven't taken it apart yet but that is what I was leaning toward.
Old May 22, 2012 | 12:51 PM
TwiZted Biker
Now the time to upgrade to the 32amp system , I do shovels with these all the time takes a lot of the stupid outa the charging system and you can use the old rotors they are better made than the new ones .
Old Jun 1, 2012 | 02:36 PM
geos 73's Avatar
geos 73
1st Gear
Finally took the bike apart. The stator was fried and not sure why, it is only 2 years old was a 32 amp system. Replaced it witha spyke 32 amp setup. Crossing my fingers this one lasts a little longer.
Old Jun 1, 2012 | 04:06 PM
panz4ever's Avatar
panz4ever
Updated mine from 22 to a 32 amp system. Used Cycle Electric components. Bit more expensive but American made and with a solid reputation.
1340fxrt
EVO
26
Dec 19, 2021 08:09 AM
Rabbito
EVO
20
Jul 24, 2015 04:17 AM
FXD_noob
Sep 14, 2013 08:51 PM
06Cummins
May 30, 2013 11:55 PM
shortride
Apr 29, 2010 01:03 PM
