rear chain
Old Jun 19, 2012 | 12:21 PM
biginchhustler's Avatar
biginchhustler
Default rear chain
Old Jun 19, 2012 | 12:23 PM
biginchhustler
yes i know its dirty-- NO the seal isnt leaking like you think-- its from over oiling the chain -- yes it needs a B.A.T.H. --- i replace the rollerskate wheel these come with with a 62mm one works wayyyy better. this has to be 1 of the best ideas ever.. makes it SMOOOOOTH...
Old Jun 19, 2012 | 01:06 PM
Big Trev's Avatar
Big Trev
Originally Posted by biginchhustler
this has to be 1 of the best ideas ever...
Can't beat a bit of self praise either
Old Jun 19, 2012 | 02:13 PM
megawatt's Avatar
megawatt
Spring loaded?
I have not tried that.
I'm helping a buddy put together his bike. With the battery between the trans and rear wheel there may not be much adjustment.
This might work well on it.
Where can it be had?
Old Jun 19, 2012 | 02:32 PM
biginchhustler
check ebay -- LBV REAR CHAIN TENSIONER, VT19-0431, FOR HARLEY MODELS -- it needs some tweeking -- #1 you can NOT tighten the nut that holds the skate wheel -- it has to be lose or it will fry the bearings-- it takes a few times to get alignment of the chain to the center of the wheel --- the bearings are just skate wheels and found on ebay -- the wheel i use is a bigger diameter - it has to be cut off on 1 side to work -- the bearings can be greased they have a easy pop off cap i would add some good grease before using -- -- as above some people cant handle that others can make,fix,build,repair,design things other than just ask the guy at the bike shop for what works ..
Old Jun 19, 2012 | 02:35 PM
biginchhustler
Old Jun 19, 2012 | 02:36 PM
biginchhustler
kinda like putting 2 front heads on a shovel
Old Jun 19, 2012 | 02:38 PM
biginchhustler
Old Jun 19, 2012 | 02:40 PM
biginchhustler
pipes will exit on the left like the XR1000 -- the ends will have the honda prelude finisher cones like the ones on my bike now--- but new ones that are polished S/S
Old Jun 19, 2012 | 05:16 PM
megawatt's Avatar
megawatt
I'm gonna check into this set up.
It might work for him.
Or maybe even for myself.
Thanks
Binkster86
Apr 11, 2017 01:00 PM
Wimbo
EVO
Jan 4, 2013 07:21 PM
hardtail61
Ironhead
Dec 23, 2008 08:30 AM
ashleyrivergal
Ironhead
Aug 29, 2007 06:57 AM
strickrodt70
Ironhead
Feb 3, 2007 07:58 PM
