S&S Strker compression questions
Old Oct 27, 2013 | 08:10 PM
Dutchinohio's Avatar
Dutchinohio
5th Gear
Default S&S Strker compression questions
I am looking for others' thoughts and experiences with reliable, streetable big inch shovels. I have an FL with a 98" S&S Shovel in it with just a few (less than 300) miles on it. I have a high torque starter and an Antigravity lithium battery. Still very hard to turn over with the starter. I can kick it easier. To use the starter I hit the button as I kick it through with the kick start.
I am at a point where I am either going to sell the 98" and put in a stock motor or do something with compression on this one. Would reducing compression to the 8-9:1 ratio still make this bike perform well without the hard starting issues? What about cam for a reliable street set up in a stroker. Currently running an S&S G carb. If I want to turn the compression down a bit would a Super E or an CV be a good choice on a 98"?
Basically, I have this monster motor and I am not a monster bike guy. I want it to be a reasonable motor that I can kick or push the button and actually have it roll over. Thanks for any thoughts!
I know S&S has many piston choices available. Can anyone direct be to choices with the +0.200 jugs to get a more reasonable compression ratio?
Old Oct 28, 2013 | 06:23 AM
Tom84FXST's Avatar
Tom84FXST
What kind of ignition are you running? An electronic that delays the spark for 2 revolutions will help.
Spyke makes starters that will turn over that motor with no problem, but they are pricey.
Ultima makes copies of the spyke starter...I have run one for 3 years without problems...never tried it on a big inch, high compression motor...but it turns the 80" over like the plugs are out.
Old Oct 28, 2013 | 07:45 AM
Dutchinohio
5th Gear
Currently running points and already have the hi torque starter. Not interested in an electronic withe the delay because I want to be able to kick the bike as well. I really am thinking I want to reduce compression overall. Maybe reducing static compression with more cam duration would help. That's what I am trying to figure out.
Thanks for the input!
Old Oct 28, 2013 | 07:46 AM
Dutchinohio
5th Gear
Currently running points and already have the hi torque starter. Not interested in an electronic withe the delay because I want to be able to kick the bike as well. I really am thinking I want to reduce compression overall. Maybe reducing static compression with more cam duration would help. That's what I am trying to figure out. Thanks for the input!
Old Oct 28, 2013 | 04:51 PM
johnjzjz's Avatar
johnjzjz
your assumption is correct about the static compression - when the cams duration is narrow it close's the valve to soon / the squeeze distance is lenghtened causing high static,
the old sifton 107 is what some guys used back in the day / none of the ( new vo cam ) companys understand or dont care about the dynamics of a shovel motor with duration,
that 107 cams intake is longer than the exhaust if you need the specs i can put them on but you are on the right track - i would also use 7 to 1 pistons that motor is so big it will pull anyway and you can use regular fuel -- been doing this 2 weeks now and that is my idea -- johnjzjz
PS dump the points and install a bearing advance mech and use a dyna duel fire ignition it will help Lots been the spot your in many times
Old Oct 29, 2013 | 09:05 AM
Dutchinohio
5th Gear
Thanks, Johnjzjz... That's the input I am needing. Can you direct me to the part number for the pistons? I imagine it's on The S&S site but I haven't been able to decipher it. I see they offer the service of fitting the new pistons. Maybe I can just send the jugs to Wisconsin and be done with it. You referenced the Sifton cams back in the day. I know they were awesome cams at one point but I get mixed reviews since Tedd Cycle bought the name. Have you run across any comparable cams from some of the other sources like Andrews, Crane or Leinwebber? Also have a Dyna S saved in my eBay searches for the ignition. I was leaning that way already. :-)
Thanks again for the input.
Old Oct 29, 2013 | 09:40 AM
Imold's Avatar
Imold
Have you considered a compression release? My S&S EVO 96" with a beefier starter sounds like it struggles sometimes, and no kick start; I've thought about compression release, just isn't in the budget right now. I don't know if S&S makes a shovel compression release, but I've read about aftermarket releases.
Old Oct 29, 2013 | 11:05 AM
Dutchinohio
5th Gear
I thought about compression releases but honestly I just don't want high compression. I would be pulling the heads for machine work (which means pulling the motor with the +.200 cylinders) anyway. I am after a tamer easy starting, lower maintenance motor. Honestly, I wouldn't buy a 98" motor normally but the bike was a great deal from a friend. As cool as the stroker is, I would be happier with a fresh 74".
That's a heck of a note, huh? While other people spend money to amp their motors up, I want to tune mine down. :-)
Thanks!
Old Oct 29, 2013 | 05:09 PM
biginchhustler's Avatar
biginchhustler
ditch that cam and use one from blackwidow the 468+ I have used them in 100+" engines that are 10:5:1 and I can kick start them even in the winter --
Intake: 31/64 275 0.445 Exhaust: 64/31 275 0.445 Overlap: 60
Old Oct 29, 2013 | 10:39 PM
Stogie Mark's Avatar
Stogie Mark
Stage I
Look into the electronic ignition systems that have a "kick-start" mode. It retards the timing only during starting. I put one on a customers bike and in a kick mode the thing fired off easy. That was after I replaced the old cables.
I want to say it was a twin-tec product but I'd have to double check.
