Isolated Primary
Old Dec 19, 2013 | 07:33 PM
DanMan1's Avatar
DanMan1
Default Isolated Primary
what should the oil level be in a isolated primary/dry clutch? Also should the oil level be checked while on the kickstand or upright on a lift?
Thanks in advance
DanMan
Old Dec 19, 2013 | 08:21 PM
johnjzjz's Avatar
johnjzjz
we put a pint of 50 W oil as thats what was used for almost 40 years in the total loss bikes and they were semi dry clutch like you are thinking about -- straight up is how i would try and check it < i would change it out at every oil change if its not leaking
Old Dec 20, 2013 | 02:19 AM
biginchhustler's Avatar
biginchhustler
"nix to engine oil-- look it up- -- use transmission fluid 1 cup -- also they make a primary oil bel-ray --- http://www.motorcyclepartsmegastore....FSRk7AodIEAAYQ ---
engine oil will make for harsh clutch action,sticky plates --
Old Dec 20, 2013 | 09:24 AM
Grinder Bill's Avatar
Grinder Bill
Stop and think about that for a minute...
Old Dec 20, 2013 | 06:50 PM
DanMan1's Avatar
DanMan1
bump, still looking for answers
Old Dec 20, 2013 | 07:22 PM
johnjzjz's Avatar
johnjzjz
types of oil i have tryed in the shop
sporty trans oil as its for chains and clutches - yep did the job at twice the cost od 50W
ATF both dextron 3 and ford type F - both used in front wheel drive automatics chains and clutches - dexron is smoother in its engagment // type F is grabs quicker < good for hot rods But leaks easy and it is gone in an hour if your not looking
Multi weight like jap bike engine oil any of them for this they are all the same - and they also do the job BUT always a BUT leaks easyer than the others
Gear oil 85 / 140 or 75 / 90 nope to thick and ends up being an issue after a while
primary oil we tryed a few types they all did the job made for gears and chains
i have seen bikes with 2 quarts in them and not leak i have seen a cup of oil leak everyplace that has a bolt --
Today we leave it as was intended and change the oil regularly just my take - johnjzjz
Old Dec 21, 2013 | 12:14 AM
FilthyLucre's Avatar
FilthyLucre
Today we leave it as was intended and change the oil regularly just my take - johnjzjz[/QUOTE]
Ditto on the above. Leave the sealed primary to the Evo's
Old Dec 24, 2013 | 05:50 AM
DanMan1's Avatar
DanMan1
6 oz and check upright.
Old Dec 26, 2013 | 10:58 PM
Grinder Bill
Courtesy Hawg:
As far as oil, it only takes about 1/2 quart or so. Just have somebody set on the bike in an upright position, pour the oil in through the derby cover until it just touches the bottom of the clutch shell and you're set. You don't need to have the chain in the oil, it only needs to be enough oil so it contacts the bottom of the clutch shell...as the clutch shell spins, it'll sling the oil around and lube the chain no problem, guaranteed.
P51Driver
May 19, 2013 09:23 PM
masterblaster
Jun 27, 2012 12:00 PM
manny10
Shovelhead
Jun 19, 2012 04:51 PM
aoehero
Oil Archive (no new posts)
Jun 16, 2011 09:44 PM
skos
Apr 20, 2008 02:19 PM
