Engine temp vs head temp
Old Aug 31, 2015 | 01:36 PM
rsking45's Avatar
rsking45
Default Engine temp vs head temp
What should the degree temperature be between the two
On the 103 motor. I've noticed that the head temperature runs about 100 degrees hotter than the engine temp. The engine temperature is right around 250 in the head temperature runs around 350.
Sounds about right?
Old Aug 31, 2015 | 05:58 PM
misfitJason's Avatar
misfitJason
Mines the same
Old Aug 31, 2015 | 06:13 PM
TriGeezer's Avatar
TriGeezer
Sounds about right?
How are you measuring these?
Old Aug 31, 2015 | 06:18 PM
J929626's Avatar
J929626
From Jamie at FuelMoto:
There are several temp related channels within the Delphi ECM. The most common channel used is Engine Temperature which is based directly off the 0-5V signal from the ET sensor on the front cylinder head, this channel is reported on the databus as ET. Generally speaking when we speak of engine temp we refer to the data from this channel, we usually consider 240-320F about the normal range relative to conditions, engine mods, and other variables. The second channel is Head Temperature which this is a bit more complex, it is a model the ECM calculates based on the ET sensor, the intake air temp (IAT) and other factors. Head Temp is used within the ECM primarily for Spark Temp correction, for most combination it will run between 260-400F. Note: Heat Temp has been recently added to the PV channel list an is reported as HeadT. The last channel is Coolant Temp which is active on twin cooled and V Rod applications. Hope this info helps...
Old Aug 31, 2015 | 06:35 PM
rsking45's Avatar
rsking45
Using my power vision from Fuel moto
Old Aug 31, 2015 | 06:40 PM
rsking45's Avatar
rsking45
Thanks for the input. So a motor running at 250-270 and head temp 350-370 while cruising is good nothing to worry about?
Thanks
Rich
Old May 30, 2023 | 11:40 AM
FLTRI17's Avatar
FLTRI17
Thanks
Rich
Consider this… since some of the Trikes “normally” run 300-400 degs engine temps in summer weather, yours seems cool by comparison.
Bob
1 2 many
General Topics/Tech Tips
May 30, 2018 03:44 PM
adm
Apr 20, 2016 11:49 PM
hemi1300
Jun 13, 2015 11:30 AM
Yo Nadz
Jun 20, 2014 10:32 PM
Brick0044
Nov 19, 2012 01:34 PM
