Lifter installation question
Old Jun 25, 2016 | 07:43 PM
Mberlin74's Avatar
Mberlin74
Default Lifter installation question
The lifters that I removed had a single flat on one side of the lifter for the anti rotation pin to sit up against. I'm installing S&S lifters which have flats on either side of the lifter. I'm assuming that I can put the lifters in and use either of the two flats per lifter. Is that correct? Wasn't sure if there was a reason to having two flats per. I'm pretty sure I know the answer but have messed up before making assumptions about what I thought was the obvious.
Thanks for the help
Old Jun 25, 2016 | 09:04 PM
baloot-boy's Avatar
baloot-boy
I just replaced my woods lifters with S&S lifters a few weeks back. My owners manual says to point the oil hole inside towards the motor.
Old Jun 25, 2016 | 09:44 PM
Mberlin74's Avatar
Mberlin74
Man i'm glad I asked. Thanks for the tip. Either I missed that in the manual or it's not there. Gonna check again. Thanks
Old Jun 25, 2016 | 09:52 PM
QC's Avatar
QC
I believe the S&S lifters are non-directional, but I aimed the hole to the inside to line up with the hole in the block.
Old Jun 26, 2016 | 08:56 AM
djl's Avatar
djl
Doesn't matter which way the oil hole is oriented; it will fill and pressurize the oil galley from either direction......
Old Jun 26, 2016 | 09:48 AM
ROCKOUT Rocker Products
Sponsor
This is what I've always heard also.
For ROCKOUT information & purchasing please click the LINKS below...
__________________
NO, they DON'T all do that!
Also on amazon.com...
Old Jun 26, 2016 | 10:24 AM
multihdrdr's Avatar
multihdrdr
Oil hole is open to reduced diameter area (shown in green). Oil "passage" is "sealed" at areas shown in red. Pressure makes oil find every hole (and controlled "leaks") it can
Old Jun 27, 2016 | 04:03 PM
Mberlin74's Avatar
Mberlin74
Makes sense. I already positioned the lifter oil hole towards the engine as per the manual but still good to know it doesn't matter. Anyone know the reason the manual directs you to position the hole inboard?
Old Jun 27, 2016 | 07:20 PM
msocko3's Avatar
msocko3
I can only assume they feel the need to state something. I've removed lifters from stock engines and found them both ways, one engine had 3 lifters facing in and one facing out, guy must have been on a bender before he installed the lifters.
Robb Liupo
Aug 4, 2018 05:10 AM
GoofySB
Engine Mechanical Topics
Feb 22, 2016 03:12 PM
jerseydog
Exhaust System Topics
Mar 29, 2011 09:00 PM
John5395
EVO
Jan 13, 2011 04:11 PM
sneeky7374
Shovelhead
May 3, 2010 08:23 PM
