Mousetrap on Shovelhead?
Old Nov 19, 2025 | 08:26 AM
rodfun's Avatar
rodfun
Default Mousetrap on Shovelhead?
Just acquired a nice 76 Shovel to keep me busy over the winter. The bike included a new Rivera Primo clutch kit that the previous owner had bought, but not installed. I had a vintage bike shop install it for me, since I've never worked on old Harleys before, and I think they did a good job.
I thought the Rivera would make the clutch lever easier, but I still find it to be a hard pull. I've had some surgery on my left hand and may be having some more. My grip is not that weak, but I get tired if I have to pull this clutch a lot on a longer ride.
So I've been googling some forums and it seems like you can fit a mousetrap on a Shovel FLH by replacing the stock clutch arm with a '65-'69 clutch arm. I found a nice used one on eBay that I ordered and I'm going to see if that actually fits before I order the mousetrap. I have one lined up a Dennis Kirk here and they have a good return policy if I can't get it to work. So that's my plan.
Just thought I'd float this on the forum here to see if anyone might have experience and any advice. One post suggested Harley may have had more than one generation of mousetrap??
Thanks!
Old Nov 19, 2025 | 09:19 AM
Ohio HD's Avatar
Ohio HD
First I would determine what clutch spring you have. Below are the spring options that a Rivera clutch has. I suspect you don't need a high performance clutch, so the lightest spring should work for you.
Black spring - stock performance
Silver spring - performance usage
Gold spring - competition performance
Rivera Diaphragm Clutch Springs
Old Nov 19, 2025 | 09:42 AM
Joe12RK's Avatar
Joe12RK
Also, make sure the clutch cable is in good shape. They do wear out and become harder to operate. I was amazed the difference made when I installed a Barnett cable on my FXR. A cheap cable only made it worse before I wised up.
Old Nov 19, 2025 | 11:12 AM
Mike1956G's Avatar
Mike1956G
Hi rodfun,
I haven't really dealt with the "server coupling", also known as the "mousetrap".
Perhaps this attached guide in German will be helpful.
Source: http://shovelschuppen.de/index.html
(The website is a bit "old-fashioned", but full of information for Shovelhead owners...)
Translating this small file shouldn't be a problem, but if it is, I'd be happy to help...
Mike
PS We Germans are detail freaks, even without knowing anything about it, but it's also fun to explain something simple in the most complicated way possible...
Old Nov 19, 2025 | 02:44 PM
john lee's Avatar
john lee
i made my stock fx clutch easier at the lever by adjusting spring tension nuts out 1 turn
Old Nov 20, 2025 | 06:27 AM
rodfun's Avatar
rodfun
Awesome feedback. Thanks! I'm going up to visit the mechanic who put in the new clutch TG weekend and I will bring up all of these questions and suggestions.
Old Nov 20, 2025 | 07:37 AM
FL54's Avatar
FL54
My ‘67 FLH came with a mousetrap on it. I installed mousetraps on both ‘68 and ‘69 FLHs. They work well and definitely ease the pull on a stock clutch. I don’t know about the Rivera. Adjusting can be a challenge the first time around but it’s worth it. IMHO.
Old Nov 20, 2025 | 08:02 AM
eighteight's Avatar
eighteight
BMI Karts has the mousetrap cables for cheap
Old Nov 20, 2025 | 02:25 PM
johnjzjz's Avatar
johnjzjz
Spring balance is the key for the trap big lever spring just a bit tighter then the clutch hat - in place then turn the spring in the mouse till the lever falls forward is the softest look in the factory book it shows all the locations of everything to get it right
Old Nov 20, 2025 | 08:03 PM
TwiZted Biker's Avatar
TwiZted Biker
That clutch kit and mousetraps do not play well together, Panz4ever and I fought that battle for a week on a sweet pan hardtail he did for his niece, we never could get it to operate correctly. The mousetrap over travels the throw out arm and the spring plate bows out to far popping over the wrong way, it was infuriating. Stock clutch setup works sweet, no MT it works sweet, together? Ain't happening.
Contact Panz and ask he'll fill you in, I have that clutch pack sitting on my bench still .
