Help!
Old Nov 7, 2014 | 11:30 PM
Mikes01deuce's Avatar
Mikes01deuce
Default Help!
Im changing my lifters on my 01 deuce and was wondering how much oil to put in it to start off with. Any help would be great. Thanks in advance.
Old Nov 8, 2014 | 04:09 AM
Spanners39's Avatar
Spanners39
3 litres if you changed the filter 2.7 if you didn't, ride until its a operating temp and then re-check the oil level.
Old Nov 8, 2014 | 07:22 AM
tbonetony06's Avatar
tbonetony06
Are you talking what leaks out when you change your lifters without a complete oil change at the same time? No clue but I don't know why anyone would put new lifters in and leaving in the old oil.
Old Nov 8, 2014 | 11:34 AM
Mikes01deuce
I opened the cam cover to install a zipper shim so how much oil then. I did drain the oil. Thx
Old Nov 8, 2014 | 03:34 PM
olongapo1's Avatar
olongapo1
Just fill the oil tank to the proper level measured on the dip stick. Re-check the oil later after the engine and oil have reached operating temperature. The amount of oil lost by opening the cam chest is not enough to cause any problems. Note: When you start the bike, you may hear noise from the new lifters until they fill with oil. This is normal and should only last a couple minutes. During this time keep the engine at idle until the noise dissipates. Additionally, during installation insure that the oil holes in the side of the lifters is facing the correct direction.
Old Nov 8, 2014 | 04:10 PM
Mikes01deuce
Which way do the holes in the side of the lifter go?
Old Nov 9, 2014 | 03:13 PM
olongapo1's Avatar
olongapo1
The oil passage hole in the side of the lifter must face "Outboard" away from the bike. I'm curious, Why are you changing your lifters?
Old Nov 9, 2014 | 04:52 PM
Mikes01deuce
Ive got almost 50k on bike and was putting in zipper shim any ways.
23Seven
Oil Archive (no new posts)
27
Jul 3, 2019 04:51 PM
fatboy1729
Feb 26, 2014 07:33 AM
JW/SECO
May 25, 2011 08:33 PM
DSSWLD
Apr 16, 2007 04:34 PM
nutsy
Mar 10, 2006 10:09 AM
