Stripped!
Old Dec 2, 2014 | 05:37 PM
Dieselvol's Avatar
Dieselvol
Originally Posted by sLow5Rider
With my bolt it was stripped at the top of the head. I was able to hammer in an extended torx tip in there and use an impact gun.
That's my plan too. I got lucky and stripped the "easy" side, so I can just use a regular Torx.
Old Dec 2, 2014 | 09:17 PM
Dieselvol's Avatar
Dieselvol
Heat, PB blaster, a Torx socket, and an impact wrench...and failure. Any other suggestions?
Old Dec 3, 2014 | 08:42 AM
im's Avatar
im
Drill time. Due to inset head of hex/allen bolt it will require a drill bit slightly wider than the hex/allen hole in the bolt.
Make a collar/ liner for hole in slider.
A plastic tube or electrical or copper pipe in the hole to help protect just in case the drill bit slips.
A collar on the drill bit helps also when trying to center but it hinders the view a bit.
Then just drill.
I had to do this before and it was not fun but it was over after a few minutes once i figured-out my process.
I suggest you purchase 2 new bolts first and make sure you have the desired drill bits and test "fit" the drill bits.
Old Dec 3, 2014 | 08:59 AM
96roadking's Avatar
96roadking
McMaster-Carr sells tapered tools for just this purpose. I have used them for years at work. Those klutzy operators strip out socket head cap bolts all the time.
Old Dec 3, 2014 | 10:42 AM
im's Avatar
im
Like a screw extractor for hard to reach areas?
http://www.mcmaster.com/#screw-extractors/=uv495b
Old Dec 3, 2014 | 10:47 AM
dfwhockey17's Avatar
dfwhockey17
What out of the old forks do you need for the new monotube/chrome slider install?
Old Dec 3, 2014 | 10:36 PM
Dieselvol's Avatar
Dieselvol
The slider tube and one of the springs, supposedly. It's my understanding that the bottom bolt had to cone off to be able to get it all apart. Maybe that's not true. At any rate, I wimped out, carried to the Harley and they go the bolt out for me. He charged me half an hour for it, which is plenty in my opinion, but it's done now. I'll move on into the next phase of taking the forks apart tomorrow night.
Old Dec 4, 2014 | 10:10 PM
Mike NY's Avatar
Mike NY
Had the same issue when I chromed my lowers. Finally tapped a straight edge screw driver into the head that made a slight indent, enough that i was finally able to turn the bolt.
Mike
NY
TheBanditColorado
EVO
27
Oct 11, 2015 06:47 AM
phillyrube
Jun 15, 2012 01:04 PM
wallah
Nov 28, 2010 12:52 AM
JDixon
Feb 29, 2008 09:09 PM
nobody
Mar 20, 2006 10:37 PM
