Broken front fork pinch bolt HELP
Old Sep 7, 2013 | 10:28 PM
TheBanditColorado's Avatar
TheBanditColorado
Default Broken front fork pinch bolt HELP
My front fork pinch bolt snapped off at the end tonight when I was finishing up a front wheel bearing and break pad job.
I found a thread on the forum where people talked about this happening but couldn't find any instructions on how to fix other than "went to the dealer and bitched" ...."then they charged me way too much money"
https://www.hdforums.com/forum/softa...snapped-2.html
any help with a how to fix is greatly appreciated... I want to get it fixed and go ride. It looks like a major problem to me so hopefully there is a DIY fix that won't involve any welding.
Old Sep 7, 2013 | 10:43 PM
cowboy 51's Avatar
cowboy 51
did you just break the bolt or break the part on the lower leg? if just the bolt a easy out should do the trick , if the lower leg , My I would start looking for another lower leg or a super good welder , but my 2 cts is replace the leg much safer
Old Sep 7, 2013 | 11:08 PM
TheBanditColorado
It's just the tip of the bolt... guess I'll be easy outing here soon. Annoying. I found a thread on another forum by doing an internet search that said to do the same thing. Easy Out then replace with stronger bolts.
PITA
Old Sep 7, 2013 | 11:20 PM
cowboy 51's Avatar
cowboy 51
IF you can drill a hole in the middle first then easy out , just enough to make the easy out work right
Old Sep 7, 2013 | 11:25 PM
Spanners39's Avatar
Spanners39
Weld a nut on the end of the snapped off bolt and wind out with a socket, the heat of the welding makes it come out real easy.
Old Sep 7, 2013 | 11:27 PM
lowered907's Avatar
lowered907
Mine broke too. But a left drill bit then an easy out took it right out. Hardly any effort
Old Sep 8, 2013 | 07:18 AM
HarDlife's Avatar
HarDlife
Use a quality extractor (i.e., E-Z out)! Don't use those cheap HF/Walmart/McDonald's? extractors! They break more than they work, and you will have a whole new headache trying to get that sucker out!!
Old Sep 8, 2013 | 11:31 AM
SoonerSoftail's Avatar
SoonerSoftail
I just drilled the center of the bolt from the back side. The bolt spun itself out before the drill bit got all the way through.
Old Sep 8, 2013 | 12:51 PM
Dr.Hess's Avatar
Dr.Hess
Start out with a left hand drill bit. Go bigger and bigger until there is little of the bolt left. Then try an easyout (which have to be misnamed.) I actually prefer the cheap harbor freight versions because when they snap off, they are much easier to get out than an actual Easyout brand of tool steel, which break off leaving you screwed.
Old Sep 8, 2013 | 01:53 PM
Yankee Dog's Avatar
Yankee Dog
YES!!! reverse drill bit is the way to go.
Don't run the risk of snapping an easy out! Reverse drill bit and if needed make/use a drill guide.
Just a simple piece of steel with a hole drilled at the proper location and clamped in place will make a great drill guide. Even better a cheapo C-clamp with hole drilled and clamped over the bolt head.
Just use the guide to get the hole started in the proper location then remove clamp so when using the reverse bit the bolt has room to back off. YD
