Shock bolts?
Old Jan 18, 2015 | 06:56 AM
Slamed Slim's Avatar
Slamed Slim
Default Shock bolts?
How do you replace your shock bolts with out a press or taking them to a shop. I was hoping to do this myself at home? Ideas?
Old Jan 18, 2015 | 08:03 AM
WKNDS's Avatar
WKNDS
Have you already purchased the bolts? If not, I would suggest
the softail lowering kit that uses split-collars. No shock removal
is necessary. It's an easy DIY job, took me maybe 45minutes...
Here's a link to the softail lowering kit.
If you already have the bolts, yes I think you have to totally remove
the shocks and take them to someone with a press.
good luck,
T.
Old Jan 18, 2015 | 04:29 PM
jreichart's Avatar
jreichart
Do a search, but use google instead of the crappy search engine on here. I took mine to a shop, but there are plenty of ways to redneck engineer a makeshift press, using bottle jacks, car jacks, bench vises etc. just need enough pressure to compress slightly to be able to remove the split retention ring. Not the safest way to do it, but it can be done.
Old Jan 18, 2015 | 04:36 PM
professorzoogy's Avatar
professorzoogy
there is a vid on youtube of some Aussie guy using a drill press .....worked out easy enough . try " installing a softail lowering kit without a hydraulic press " .
Old Jan 19, 2015 | 04:39 PM
brockND's Avatar
brockND
my kit just came in Saturday and was hoping to due it myself as well. I watched this video he is talking about and it looked pretty easy. It seems like a lot ppl have pulled it off themselves.
Old Jan 21, 2015 | 08:43 PM
Wrenchy's Avatar
Wrenchy
I just put lowering bolts in my shocks.. have a press at work so I used that. That's the safest way to do it tbh. Can always look up other ways on YT or google.
CSS_FXD
Oct 11, 2013 11:53 AM
Toy_Jon
May 7, 2010 03:56 AM
neocontra
Jan 3, 2010 06:55 PM
ski917
Jul 24, 2009 11:48 AM
jd8181
Jul 10, 2009 05:05 AM
