Night Train springer bobber styled
Old Jul 21, 2015 | 06:37 PM
  #371
splattttttt's Avatar
splattttttt
Originally Posted by Ink83
Nah I'm still away for work at the moment and at this stage it looks like bad weather for the time I'm home next, so I'll see how it goes
Lookin forward to seeing more of your magic soon ink
Thanks for the reports on the RB exhaust, love that system, just so expensive
Old Jul 22, 2015 | 05:13 AM
  #372
Ink83's Avatar
Ink83
Thanks Splatt!
My regulator looks a bit on the well worn side of things, not something a sand blast and paint could fix.
So I'm going to buy a new one and wondering if there's any point in buying an after market one or just another factory one.
I don't see much point in a higher performing regulator (well so they all seam to state with no comparison tests to show), unless you have a bagger where you've added all the gagets under the sun pulling more continuos amps, right?
Does anyone have any input on this? I know people get a faulty regulator then go buy an aftermarket one with the idea they needed a regulator they states to be better then the factory one, but is there any real evidence that shows its needed on bikes like this, and that it's not just what it is, a faulty regulator that needs replacing? Everything I read on aftermarket regulators, suggests these factory 3 phase regulators in my night train should be plenty
Old Jul 22, 2015 | 05:52 AM
  #373
WKNDS's Avatar
WKNDS
Thanks Splatt!
Might consider a more efficient regulator from Cycle Electric.
Probably same price as HD.
T.
Old Jul 22, 2015 | 07:16 AM
  #374
Ink83's Avatar
Ink83
I did check them out, maybe I missed something and correct me if I'm wrong, but from what I remember he explains 3-phase systems work so much more efficient then factory regulators. This would be true with older single phase regulators, which must be what he's refferring to but worded it to sound like all Harley regulators, but these Harley having been using 3-phase systems for years now.
Am I missing something? Because I rarely ever see anything but factory regulators being used on bikes with a lot more going on
To me in Australia, the difference is about $300 for the cycle electric regulator and $150 for stock. Just seams like a lot of word trickry used, which a lot of company's use these days to make sales. So is there any evidence to say that it's any better the stock 3-phase for a night train? Or just the evidence that says 3-phase systems are much more efficent then single phase? Im interested in knowing more about this
Old Jul 22, 2015 | 07:39 AM
  #375
1004ron's Avatar
1004ron
To control voltage on Harley-Davidson alternators other rectifier regulators dump current to ground. This causes maximum stator current and temperature at all times. Cycle Electric rectifying regulators block current to control voltage. This reduces stator current resulting in lower temperature and less drag on the motor which means more efficient operation.
Both regulators are 3-Phase.
The Harley regulator uses what is called "Crowbar Regulation", which means it shorts the 3-Phase stator windings when the output voltage reaches the set point of around 13.8 volt. This is less energy efficient, but should not cause damage seeing as the stator is designed to handle this "short circuit" condition.
The Cycle Electric regulators use a "controlled 3-Phase Bridge Rectifier" which interrupts the charging current/voltage when the set point of 13.8v is reached, which is more energy efficient.
I first came across this on a Ducati that I restored - I carefully picked out the potting compound and back engineered the failed rectifier-regulator for this project.
Update:
I do not know for sure that the HD rectifier/regulator is the crowbar type, just presenting an explanation to the claim made on Cycle Electric web site.
Old Jul 22, 2015 | 09:31 AM
  #376
Ink83's Avatar
Ink83
That's exactly what I wanted to hear. That makes sense compared to the info I read. Thanks very much Ron
Old Jul 22, 2015 | 09:56 AM
  #377
Ink83's Avatar
Ink83
"To control voltage on Harley-Davidson alternators other rectifier regulators..."
This doesn't say it's Harley Davidson regulators, it just says on Harley's, other regulators use the less effect system. This could mean other regulators made for Harley Davidsons. It doesnt clearly state it's the factory Harley regulators, yeah? Or is there info elsewhere that says that Harley regulators are in fact what is lead to believe?
Have no doubt cycle electric make good quality products, just hoping to clarify I'm not wasting money if I bought there regulator
Old Jul 25, 2015 | 11:49 PM
  #378
IrIeSpringer420's Avatar
IrIeSpringer420
Default Night Train springer bobber styled
I have been off for a while. Been dealing with a big move. Man the bike is coming together bad ***!
Old Jul 26, 2015 | 07:02 AM
  #379
Ink83's Avatar
Ink83
Thanks man, been really slow going, but it's all starting to fall into place.
Couple new pics with pipe on. Also repainted the oil tank in wrinkle and got that all in with the lines hooked up. Worked on the new coil mount today and bent the tank shift a little closer to the tank.
A good buddy of mine made up a side mount bracket for my number plate while I was using his gear making up the coil mount and front indicator mounts as well as the main on switch and indicator lights panel, will get pics up of these when they're finished.
Old Jul 26, 2015 | 07:06 AM
  #380
WKNDS's Avatar
WKNDS
The Cycle Electric regulator for the Softails looks a bit different than stock as well.
The way it looks might affect your decision one-way or the other.
So here's what it looks like on my Slim.
hope this helps,
T.
