2011 heritage softail
Old Jan 26, 2015 | 11:00 AM
HeritageFathead's Avatar
HeritageFathead
1st Gear
Default 2011 heritage softail
Bike will not start in gear is this suppose to happen thanks in advance
Old Jan 26, 2015 | 01:54 PM
mkenkel's Avatar
mkenkel
it should if the clutch is pulled.
Old Jan 26, 2015 | 02:44 PM
Bone Doc's Avatar
Bone Doc
Yes, the bike should start in gear with the clutch disengaged (lever pulled in). Did you change clutch levers or switch to an aftermarket clutch lever prior to this happening?
There is a clutch safety switch inside the left housing that is activated by a tab on the clutch lever. Some aftermarket levers don't have the tab and cannot activate the switch.
My guess is the clutch safety switch is bad. The switch is part 72942-11 and costs about $25 +/-. It is a very easy repair.
It's not critical to leave your bike that way but, if you stall while moving, you would have to put it in neutral to start the bike instead of just pulling in the clutch.
Max Headflow
Milwaukee Eight (M8)
38
Nov 10, 2020 08:17 AM
casique
Aug 4, 2014 07:39 PM
JakesDad1
Nov 26, 2010 01:56 PM
Pony Soldier
General Topics/Tech Tips
Sep 10, 2010 12:46 PM
CLL375
Aug 14, 2006 04:25 PM
