Front brakes
It might be that it just takes some gettin' used to, since the bike is much heavier than what I'm accustomed to. Both my Sportster and Triumph Bonneville will stop very quickly with only moderate pressure on the lever. The softtail seems to respond better with using more rear brake, and needs a good bit more pressure on the front to haul 'er down quickly
Post back how the Lyndalls work for you, seems they do well for everyone that's tried them.
I stand by my statement that the OP should use DOT 4 brake fluid if he chooses to change the fluid.
Here is an excerpt from the 2006 Softail Owners Manual :
Brakes
Inspect brake pads for wear at service maintenance intervals. If you ride under adverse conditions (steep hills, heavy traffic, etc.), inspect more frequently. Excessively worn brake pads can lead to brake failure, which could result in death or serious injury. (00052a)NOTES:
- Master cylinder cover specifies correct brake fluid.
- When adding or changing brake fluid, be sure to use only the type specified for your motorcycle.
- Use only Harley-Davidson D.O.T. 4 HYDRAULIC BRAKE FLUID (Part No. 99953-99A).
- Do not mix D.O.T. 4 with D.O.T. 5 brake fluid.
- Refer to Regular Service Intervals: 2006 Softail Models. Check brake pads and brake discs for wear at proper intervals.
- Check the fluid level in the master cylinder reservoirs at proper intervals.
- If level is low, clean dirt and debris from reservoir cover before removing.
D.O.T. 4 brake fluid will damage painted and body panel surfaces it comes in contact with. Always use caution and protect surfaces from spills whenever brake work is performed. Failure to comply can result in cosmetic damage. (00239b)
Direct contact of D.O.T. 4 brake fluid with eyes can cause irritation. Avoid eye contact. In case of eye contact flush with large amounts of water and get medical attention. Swallowing large amounts of D.O.T. 4 brake fluid can cause digestive discomfort. If swallowed, obtain medical attention. Use in well ventilated area. KEEP OUT OF REACH OF CHILDREN. (00240a) - Add D.O.T. 4 HYDRAULIC BRAKE FLUID (Part No. 99953-99A) if necessary.
Use only D.O.T. 4 HYDRAULIC BRAKE FLUID (Part No. 99953-99A) approved for brake system use and available from your Harley-Davidson dealer.
Harley-Davidson has provided your new motorcycle with the optimum brake pad friction material available. It is selected to give the best performance possible under dry, wet and high operating temperature conditions. It exceeds all regulatory requirements currently in effect. However, during some braking conditions you may experience noise. This is normal for this friction material.
Brakes are a critical safety component. Contact a Harley-Davidson dealer for brake repair or replacement. Improperly serviced brakes can adversely affect brake performance, which could result in death or serious injury. (00054a)See Measuring Brake Outer Pads. Visual inspection of brake pads can be made without removing the caliper. View the lower area of each caliper with a flashlight.
Perform routine scheduled brake maintenance. Lack of maintenance at recommended intervals can adversely affect brake performance, which could result in death or serious injury. (00055a)
Always replace brake pads in complete sets for correct and safe brake operation. Improper brake operation could result in death or serious injury. (00111a)NOTES:
- If the brake pad friction material is 0.04 in. (1.02 mm) thick or less, the pads must be replaced immediately.
- Always replace brake pads in pairs.
The rear brake outer pad on all models can be measured from the caliper bracket side using a thin plastic 6.0 in. (152.4 mm) rule. Place the rule against the brake disc through the space alongside the caliper.
The outer surface of the brake pad backing plate should measure 0.04 in. (1.02 mm) or more away from the brake disc.
NOTE:
Replace pads if brake friction material (1) is 0.04 in. (1.02 mm) or less above the backing plate.
- Front brake bottom view
- Rear brake top view
I saw the question mark in your post and knew what you were thinking. My response was actually directed towards Rayvan. His comment, "Please ignore the guy who said to use DOT 4....", without a qualifying remark is inconsequential. IOW, indicate why he believes I was incorrect.
I'll live to see another day. Ride safe.
Boog
