Front brake squeaks
Old Feb 16, 2015 | 09:33 PM
Pete3323's Avatar
Pete3323
Default Front brake squeaks
My 2k heritage has just at 1500 miles on it since new. I picked it up around 4 mos ago with 347 miles. Brakes are starting to squeak a bit on front. Couldn't b pads already? Any suggestions on quieting them? Thx.
Old Feb 16, 2015 | 09:43 PM
Steven725's Avatar
Steven725
I would try to clean them first. They might have some dirt or grime in them causing them to squeak.
Old Feb 16, 2015 | 10:08 PM
jcsshane's Avatar
jcsshane
I know you guys are in drought conditions.....but if the humidity is up {something you wouldn't be used to} front brakes will squeal like a pig.
Old Feb 22, 2015 | 09:03 PM
oct1949's Avatar
oct1949
doubt they are worn out..Wondering did you flush the brale lines and you might need to clean the pads and Caliper pistons, they may be sticking a little
Old Feb 23, 2015 | 01:55 AM
Rodzilla6's Avatar
Rodzilla6
Just to be safe, check the front wheel bearing also. Most likely not it...but I had two fail under warranty...6 k on the first one and 7 k for the second, New bike stored inside...second failure happened at 65 mph...only warning was a squeaky brake...
Good thing is, a whole new set of quality bearings are only about thirty bucks.
Ride safe.
Old Mar 3, 2015 | 08:17 PM
Michael knowles's Avatar
Michael knowles
Dude check for dirt build up or glazing. Washout callipers. Buy ABS approved brake cleaner. Read instructions & be very careful applying to rotor & calliper. Cleaner can damage paint.
Old Mar 3, 2015 | 08:40 PM
Michael knowles
On another note:
I installed a display stand.
Whisker highway pegs. Parts book wouldn't fit. Simple removal of brake retaining clamp & replace with electrical sap straps pegs installed. Look awesome HD ribbed pegs.
Smurfshxt
Jun 15, 2015 10:58 PM
sledder69
Jul 3, 2012 09:15 PM
ajpuck
Jul 19, 2007 02:06 PM
dumoore
Jun 27, 2007 11:41 AM
tojo152
Mar 1, 2005 02:04 AM
