Drives me round the bend.
Old Mar 6, 2015 | 02:50 PM
gotmeaharley's Avatar
gotmeaharley
Default Drives me round the bend.
This bloody bike drives me round the bend. I had obviously heard about the Harley unreliability thing but mine is taking the ****. Half the time it suffers from temporary fuel starvation, half the time it doesn't. The other day it was fine. Stopped off to see a mate, got back on it and everytime I hit the starter the electrics cut out. We pissed about with it for an hour and then they all came back on again with no explanation. Went out today and no problems at all. I love the bike to bits but it does my head in sometimes. The trouble with intermittent problems is that they are hard to trace. I will not give in though and will sort it out.
Old Mar 6, 2015 | 02:53 PM
Wrenchy's Avatar
Wrenchy
Never said what bike you have.... professional opinion is take it to a dealer and have it looked at thoroughly for electrical problems, you clearly have some.
Old Mar 6, 2015 | 02:56 PM
gotmeaharley
a 1996 FXSTC. Don't want to take it to the dealership really, although I appreciate what your saying. They charge about 90 quid an hour labour and with it being intermittent I may end up having to remortgage my house to pay the bill lol. I'll get to the bottom of it eventually though.
Old Mar 6, 2015 | 03:06 PM
Wrenchy's Avatar
Wrenchy
Well, if you, or any of your friends are good with wiring you could always buy a manual and tear into it and check for issues.
Old Mar 6, 2015 | 03:12 PM
caberto's Avatar
caberto
My wife's previous Sportster had intermittent issues briefly and then finally would not start, it turned out there was cracked wiring within a wire harness under the seat where the wiring looped around tightly. An Independent shop found the issue the same day we took it in, and fixed it very reasonably. Hope yours is an easy fix.
Old Mar 6, 2015 | 03:27 PM
PAFXCWC's Avatar
PAFXCWC
If you are handy with the tools then I would go ahead and look into it yourself. Sounds to me like a bad connection. I would start at the battery connections and work from there. They tend to look ok on the outside but get all corroded on the in side.
Old Mar 6, 2015 | 06:19 PM
gotmeaharley
I've got a mate who's pretty good when it comes to all things electrikery so he's going to have a look. Hopefully it's an easy fix. I'm not too bad with spanner stuff but hate electrics :-)
Old Mar 6, 2015 | 06:32 PM
usmcbuck's Avatar
usmcbuck
Things like that will drive ya batty, I hate electrical stuff myself, hope you guys get it figured out.
Old Mar 6, 2015 | 06:48 PM
Dangit's Avatar
Dangit
My two cents is check your grounds. I'm not sure where your bike wiring grounds, but there are probably a couple of places. My last bike (Honda) had problems like yours then I read where one of the two wiring grounds was on a painted surface. Easy fix. Also, the least bit of corrosion on your battery terminals can result in problems.
rd
Old Mar 6, 2015 | 06:54 PM
RANGER73's Avatar
RANGER73
I've got a 94' FXSTC. Not much to them electrically. Get a manual and start from the battery. If EVERYTHING is going out check the main circuit breaker then ignition.
