Ultima 6-speed
Old Apr 22, 2007 | 03:17 PM
gatekeeper's Avatar
gatekeeper
6th Gear
Default Ultima 6-speed
Hi, I've read lots of comments on the RevTech-transmissions, but does anyone have any experience with the Ultima 6-speeds? I know a few builders use them with the Ultima-engines.
I know Baker is king, but here in Norway with installation the cost will be approx. $5500 at the stealer, but from another shop I can get an Ultima installed for $2500 or a RevTech for $3200...
Thanks!
Old Apr 22, 2007 | 08:17 PM
JacksHD's Avatar
JacksHD
Stage IV
Default RE: Ultima 6-speed
I'm about a week away from putting one in my 92 Heritage .... I'll let you know first impressions,
but I have heard good things. My original trans will not be sold for awhile! I'm hoping it's not a
600.00 lesson.
Greg
Old Apr 23, 2007 | 12:54 PM
gatekeeper's Avatar
gatekeeper
6th Gear
Thanks and good luck, I assume it is a good tranny, but then again, everbody has opinions. The dealer where I live (Norways largest) says they've never had any problems with RevTech the last years, but that the quality was a bit shoddy before. Never heard anything bad about Ultima and they match them with powerful engines, so it SHOULD be good stuff...
Old May 2, 2007 | 09:09 PM
JacksHD's Avatar
JacksHD
Stage IV
I put the Ultima in this past weekend, and 1st impressions are "Nice"!! Shifts smooth and 6th gear
is pretty cool. I haven't been able to really get on a road where I can go 70ish for any distance, but at 60, I go to 6th, and it really lowers the rpm's. At 60, it's almost too slow, but you know, you have to experiment. I know it would be nice if someone would post, that has had the Ultima for a while .... I'd like to hear too .... but as of right now, I'm a happy guy!
Hope it goes well at your end and God Bless.
Greg
Old Aug 14, 2009 | 11:04 PM
goinghot's Avatar
goinghot
Stage II
I am debating between the ultima and the baker. Bucks is bucks, Need more input first on the ultima regards longevity., Greg, consider dropping the tranny pulley to 30 and the motor to 24. Will get you out of the hole quick, and you should be able to cruise at 2800 or so at 75 in 6th.
Old Aug 15, 2009 | 07:50 AM
spooner's Avatar
spooner
For the few additional $, I think that the RevTech is a much higher quality transmission that the Ultima. I think that Sucker Punch Sally's just switched to RevTech.
Old Aug 15, 2009 | 12:42 PM
RHillbilly's Avatar
RHillbilly
I had the ultima in my old softail never had a problem they come with a 2yr 24000 mi warranty. you can get one from Jireh cycle for $599 with free shipping
Old Aug 15, 2009 | 05:29 PM
KumaRide's Avatar
KumaRide
fwiw - Did some research awhile back on the RevTech and Ultima. Given the two choices, the Ultima would go in my FB.
Old Aug 15, 2009 | 07:47 PM
miacycles's Avatar
miacycles
WE've installed a lot of Ultima's with basically no problems. We have one in our '95 FLHT with a 120" engine, 142 HP 154 Torque. we ride it like we stole it and it still shifts like butter. We put a 31 tooth pulley with it also.
Old Aug 15, 2009 | 09:15 PM
KAH24DupontChevy's Avatar
KAH24DupontChevy
Default RevTech 6spd has been around longer--I think?
I read the same that Sucker Punch Sally had issues with the Ultima and have gone with RevTech. My bike has a 6spd factory, but if I were building a custom and wanted to go cheaper than Baker 6, I'd probably choose a RevTech as my impression is that they've been around longer with their 6spd and probably have worked out the bugs a bit longer.
Karl
