Using turn Signal buttons to disable security system
Old Apr 22, 2007 | 10:37 PM
Strgzr's Avatar
Strgzr
Default Using turn Signal buttons to disable security system
Ok folks,
This requires some forum exerience. No thanks to the manual, I was able to get a code into my bike. lest assume the code is 22222.
So I arm the bike.
I hold both buttons and get the solid security light.
I hit
Left 2 times
Right 1 time
left 2 times
Right 1 time
left 2 times
right 1 time
left 2 times
right 1 time
left 2 times
right 1 final time. System does not disarm. I have worked different numbers with no luck.
If anyone knows what Im missing, please assist.
Thanks,
Strgzr
Old Apr 22, 2007 | 10:38 PM
Strgzr's Avatar
Strgzr
Default RE: Using turn Signal buttons to disable security system
P.S. I have verified the code I have selected... Thx...
Old Apr 22, 2007 | 10:46 PM
iowacruiser's Avatar
iowacruiser
The are only two things that you don't specifically mention that need to done (or not done). First, make sure you are standing beside the bike and it is still resting on the jiffy stand. If not, you probably already "tripped" the system and your code won't work to disable the alarm. The second thing is turn your ignition on before starting the procedure. If you are doing those two things, you have the procedure correct. I just tested it on mine to make sure I had it right. Good luck.
Old Apr 22, 2007 | 10:51 PM
Strgzr's Avatar
Strgzr
Ok,
I cant be on the bike... Yeah she is flashing like a Xmas tree as I was trying to do this. I did have theignition on... Lemme go try this... Thanks much!!!
Old Apr 22, 2007 | 10:55 PM
Strgzr's Avatar
Strgzr
No Joy... Just turning on the ignition causes flashing signals...
Old Apr 22, 2007 | 11:11 PM
Strgzr's Avatar
Strgzr
Ok,
Figured it out... Got to turn it to ACC vice Ignition... Thanks for the help IowaC....
Strgzr
Old Apr 22, 2007 | 11:50 PM
iowacruiser
You are welcome. 06 vs 07 is a little different. My 07 is turned to on, rather than Acc. Interesting..................... Have a great week.
Boson
Electrical/Lighting/Alarm
Mar 31, 2022 10:19 PM
bisache
May 28, 2017 12:48 AM
unyalli
Jun 29, 2015 10:52 PM
Chopperbob
Dec 6, 2012 06:10 AM
brenthall
Oct 23, 2010 11:15 AM
