Going nowhere fast!
Old Apr 16, 2015 | 11:56 AM
bech64's Avatar
bech64
2nd Gear
Originally Posted by Visago
Have the same bike, same year...just had something similar going on. I swapped out my bars with apes and bike ran fine. After all the work was done I loosened my controls and bars to adjust everything and then after I tightened it all up I was having this same issue. Found that it was blowing the ignition fuse. Took apart the throttle side controls and sure enough...one of the wires got crushed when I was readjusting everything. It was stripped and grounding out on the bars. Wrapped the bare area with electrical tape and everything is fine now but you said you checked all of your fuses already so probably not the same issue.
I may may be worth checking again! Not to get off topic but, how do you like the short shots? Did you remap fuel?
Old Apr 16, 2015 | 01:23 PM
Visago's Avatar
Visago
Ya man...check that ignition fuse, that was the culprit with mine. Love the short shots. I'm running them without baffles so it's louder than hell but I'm cool with that. I have the FuelPak so I just got the remap codes off the V&H website. Bike runs great!
Old Apr 16, 2015 | 01:38 PM
NDBadlands4-2's Avatar
NDBadlands4-2
Just to make sure it is not the Key fob, type in your security code at startup. If it still does not work, then you know it is not the security system.
ghost183
Screamin Eagle CVO Models
11
May 28, 2018 10:49 AM
Pech
Apr 23, 2018 04:04 PM
WildBill79
Apr 11, 2018 10:47 PM
wgb3470
20
May 18, 2015 07:18 AM
Roadglidin27312
Aug 4, 2010 11:49 AM
