PM grips eaten up by cable
Old May 10, 2015 | 05:05 PM
Aaron01's Avatar
Aaron01
Default PM grips eaten up by cable
Took my Performance Machine grips off my Train to change bars and noticed the cables have chewed into the aluminum. Anyone seen this before?
Attached Thumbnails PM grips eaten up by cable-pm-grip-1.jpg   PM grips eaten up by cable-pm-grip-2.jpg
Old May 10, 2015 | 05:59 PM
Misbehaven's Avatar
Misbehaven
All the grips I have used in the past few years have had plastic/nylon ends on them. Never noticed much wear on them. That seems to a little excessive to me. Are you supposed to have any sort of lube in that area? It might help to reduce the wear.
Old May 10, 2015 | 06:25 PM
pipeyeti's Avatar
pipeyeti
I have seen it on those same grips and it was caused by the friction screw pad not being on the screw end. I am talking about the little pad plastic thing that sits on top of the friction screw.
Old May 10, 2015 | 06:36 PM
Misbehaven's Avatar
Misbehaven
Good point. Those little bastards can fall out and you'd never notice it. Happened on my wife's Sportster a few years back when I changed her grips.
Old May 10, 2015 | 06:48 PM
103 sedona orange's Avatar
103 sedona orange
Just for the hell of it, call PM & ask them.
Old May 10, 2015 | 08:17 PM
Aaron01's Avatar
Aaron01
Default Bingo
Thanks, the little nylon pad is missing. I will get a new one when I put it all back together. I think the grip is still ok to use, if anything the pad might wear a bit to conform to the groove.
Thanks again!
Old May 10, 2015 | 08:29 PM
Misbehaven's Avatar
Misbehaven
When that pad falls off it's like the throttle end Ferrell's. They just vanish into thin air.
Old May 10, 2015 | 08:38 PM
pipeyeti's Avatar
pipeyeti
When it happened to mine they were never the same and would bind slightly if the pad touched the rough area again. Ended up eventually replacing the grips.
Old May 12, 2015 | 11:56 AM
Ramboamt's Avatar
Ramboamt
You could use some sand paper to smooth out the grooves and remove the bits and pieces of the aluminum that are stuck on the grip that interfere with the pad.
Extreme67
Mar 22, 2019 06:06 PM
TwoBlue02
Jul 1, 2016 08:09 PM
asg13
Apr 15, 2014 02:02 PM
Buckinfitch
Apr 20, 2011 10:53 AM
grunt999
Nov 30, 2007 07:40 PM
