Detachable windshield installation question
Old Jul 10, 2015 | 10:45 AM
blackSP's Avatar
blackSP
Removed the shield, checked the depth of the holes and they're 100% snug. I guess that's it, the shield is not going to fly off anyway. I will put a tie wrap over the bolt and hook the spring in it to be sure...
Old Jul 10, 2015 | 10:49 AM
Joe_G's Avatar
Joe_G
I don't think you have anything to worry about it flying off. I didn't put loctite on my screws and I lost an entire mount while riding, and it held on just fine. They're loctited now and I learned how expensive chrome bolts are at Ace hardware.
I'm wondering if you perhaps got a touring windshield....I wonder if the spring arm is longer on the touring I'll try to take a look next time I'm at the dealer. My springer shield wouldn't be meaningful to you so I won't bother to measure that.
Old Jul 10, 2015 | 12:01 PM
blackSP's Avatar
blackSP
Thought about that, I'm pretty sure my springs are just too short, shape's ok but not the length,
Old Jul 10, 2015 | 12:56 PM
jam436's Avatar
jam436
Originally Posted by blackSP
Guys, my dealer just installed my screen but I'm not sure about this spring. Like this it doesn't seem to do anything....
Can you please point me in the right direction?
I also have the H-D quick detach mounted on my Slim, Mine is the H-D part # 7400111 - "Windshield, 18" Light Smoke – Black Braces"
(this is the one made for use WITH auxiliary lights installed, although I doubt this makes much difference)
...and the spring clip DOES NOT wrap all the way around the bolt.
It only goes as far as to clip onto the front of the L-shaped mounting bracket...
As long as the groove in the windshield bracket is fully seated onto the rubber grommet you're good to go.
Mine has been on for over two years and has never come close to falling off...
Here's my view from the top, right side:
Old Jul 10, 2015 | 01:17 PM
blackSP's Avatar
blackSP
Well, that settles it once and for all I guess. It serves no function what so ever on our bikes. Cheap *** Harley part with no use (cahpwnu)
Old Jul 10, 2015 | 02:01 PM
jam436's Avatar
jam436
You're right about that.
It sure looks like an expensive, extra piece of hardware considering it really doesn't do anything...
But if it's security you're after check out the locking ShieldShackles.
They use the same mounting holes as those retaining springs, and they DO wrap around the bolts...
Old Jul 10, 2015 | 05:21 PM
blackSP's Avatar
blackSP
Well, 2 tie wraps wel do the trick to at 0.0001 cost 📎📎
Old Jul 10, 2015 | 05:25 PM
Joe_G's Avatar
Joe_G
Those have to be the wrong springs. You can see the slot on the mount that my springs fit into.
Now that said if you push forward on the shield the springs come right out of the slots and you can remove the shield. So they seem to be really pointless except to snag the brake line when putting on the shield.
Old Jul 10, 2015 | 05:32 PM
proraptor's Avatar
proraptor
This is exactly how my heritage is also
Old Jul 10, 2015 | 05:51 PM
WVDevil's Avatar
WVDevil
You've got a bottom bolt in a top clamp I believe. On mine, yes its a Sportster so could be different, the top bolts have a little tit that the spring goes on. Look here:
