Issues after Big Bore Kit
Old Jul 14, 2015 | 02:26 PM
mudsplasher's Avatar
mudsplasher
Check for an intake leak.
Old Jul 14, 2015 | 02:29 PM
Joe_G's Avatar
Joe_G
Originally Posted by Next In Line
Did you mix up the spark plug wires?
The Twin Cam has a specific firing order unlike previous Harleys.
Another good guess and certainly easy to check. I did that once (forgot my key and had to theft proof the bike somehow so I put the wires in my pocket) and had similar results as I think about it. Had a 50/50 shot and guessed wrong. lol
Old Jul 14, 2015 | 06:35 PM
greybeard122's Avatar
greybeard122
I agree it will need to be remapped, but it should still start and idle. Did you reuse the same pushrods or adjustable? Is it carb or efi? If efi, make sure everything is hooked up properly, map, tps,IAC engine temp etc. Chances are its something simple.
Old Jul 14, 2015 | 06:40 PM
greybeard122
Forgot to mention, check and make sure you hooked up all your grounds. One wire not hooked up will make you pull your hair out!
Old Jul 14, 2015 | 09:05 PM
Joe_G's Avatar
Joe_G
Originally Posted by misfitJason
You have two things working against you right away. Your pipes are a bad power choice and a velocity stack is a horrible thing to tune. No remap! Don't even try to start it without a remap. You are going to burn your motor up!
All due respect, but the tunes aren't so dramatic different from the stock tune that you'll burn your engine up just idling it or even riding gently. A drag strip run you might be lean enough to do some damage but even then I doubt it. I don't think we need to scare the OP like that.
But I do think he has a mechanical issue. I hope it's as easy as the plug wires reversed. And that he chimes back in to let us know what it is.
Old Jul 14, 2015 | 09:37 PM
misfitJason's Avatar
misfitJason
Default Issues after Big Bore Kit
Yes it is ^. A stock Harley runs a defined timing map with efi. Combine that with the fact that a stock bike runs extremely lean and then add a larger size combustion that would require more fuel and your starving it creating heat. Heat with new rings and unbroken in walls and new components is a very bad equation. Can lead to toasting a new motor by baking it. A tune can be a little off and that's ok. But using a tune for an 88 with timing for an 88 on a 95 is not the same as a little off. Oh and I do agree with you that he has something mechanically wrong but this can be a very large reason why
Old Jul 14, 2015 | 10:31 PM
Joe_G's Avatar
Joe_G
Idling engine is under a lot less stress than an engine under load. Tune wouldn't cause what his problem is, nor will it blow his engine up idling. I've been tuning cars for 8 years. Not an expert but this I know.
Old Jul 15, 2015 | 06:14 AM
medicmouse's Avatar
medicmouse
1st Gear
Thanks for the help folks. Tore it back down and found that the pushrods were installed incorrectly.
Crowbar1
Milwaukee Eight (M8)
11
Aug 30, 2018 09:33 PM
mmondo2k2
Aug 9, 2017 09:25 PM
magnum629c
Apr 19, 2015 01:20 AM
HOG_0308
Dec 16, 2010 06:00 PM
kmille
Aug 16, 2007 07:54 AM
