Fixing a scratched windscreen
Old Aug 26, 2015 | 11:43 AM
Dan.1977P's Avatar
Dan.1977P
It's kind of like the chiropractor. Once you start, you have to keep polishing. 10 minutes every few months isn't a big investment to me.
Old Aug 26, 2015 | 07:44 PM
Pete3323's Avatar
Pete3323
Good time to buy LRS wind screen. Not expensive and a big improvement over stock.
Old Aug 26, 2015 | 10:01 PM
RandallJ's Avatar
RandallJ
Originally Posted by Ray on the drums
That's what I'm saying but for how long though?
It takes the finish to new/near new.. it is not a coating but a polishing abrasive (albeit very very fine).
Polishing with the Ebony product is a bit of an art, it requires a pretty slow but steady path so that the wheel can heat the surface a bit (burning is the danger and product only works with a powered rotary polishing bonnet)
You would need a chemist to say whether plastic oxidizes faster as it ages but the results were pretty phenomenal.
I had on a couple instances color sanded the really bad ones first before repolishing..(worked like a champ)
Old Aug 27, 2015 | 01:17 AM
FLSlim's Avatar
FLSlim
you dont buff out scratches, you are only bringing all else around the scratch down to the level of the scratch.
so if you are telling me you are buffin out scratches I tell you are full of poop
Old Aug 27, 2015 | 06:52 AM
Ray on the drums's Avatar
Ray on the drums
I keep finding the flip out, low cut windshields used but in great shape for
40-50 bucks on Craigslist myself. I even wait till one comes up near me.
Old Aug 27, 2015 | 08:21 AM
RandallJ's Avatar
RandallJ
Well that is mostly right but not entirely.. There are a ton of products out there that "fill" scratches with waxes, oils or other fillers for a few wash jobs, then the "scratch" reappears..
Now, color sanding is the wholesale removal of top material.. Is a process used since the first guy wanted a shiney Model T.. Works amazingly well for orange peel or just to flatten a surface.. (we always used a block of some kind)
Now, when you use a powered wheel with a product like Ebony on a plastic surface, it does in fact move some material around and in fact does "fill" to a minor extent.. It does the same on paint, it heats and spreads the top surface of the coating. Get too aggressive and you burn the paint.
Ebony is very poor at removing stock.. (we actually used cornstarch and water for a long time for a slightly more abrasive media) I am more than sure there are some paint and body guys that can give a lot better explanation of this but that is my working understanding after a couple years sanding and buffing hotrods..
Old Aug 27, 2015 | 08:38 AM
Jackie Paper's Avatar
Jackie Paper
If it's a tinted Harley shield, its similar to the coated tint they put on glasses. Once it's gone, it's gone. Since you look over a shield, not sure why they do that other than to charge more. Just makes the shield more noticeable.
Someone stuck a note on mine and a few hours in the sun made a 9x11 x 1/2" wide rectangle on it when I pulled it off.
Not worth fretting over. It's just a tool. I replaced mine with clear that I like better. I got a complete new take off off ebay for less then dealer wanted for just the shield. 100 Anniversary no less. However, in a few years, even a clear one gets scratched up but at least not in big patches.
Old Aug 27, 2015 | 09:02 AM
GibT's Avatar
GibT
Not worth messing with since the clear has been worn through. Get a new one from Long Rides. They are a sponsor here and they have a very good product.
http://www.longrideshields.com/
Old Aug 27, 2015 | 07:11 PM
cocky's Avatar
cocky
+1 on the LRS. Had mine on for about 3 weeks and I like it a lot and at 16 inches I dont notice its down there.
Old Aug 29, 2015 | 03:44 AM
blackSP's Avatar
blackSP
No need for any fancy plastic polish.
Use any type of chrome of just car polish. End with the finest grade and almost all scratches will be gone, even the deeper ones. It does take a bit so don't give up to soon. What you basically do with the deep is polish away the rough surface of the scratch making it transparent again. I just removed a deep one on my new windshield (@&!^!!) and its not really visible anymore.
d1n0saur
General Topics/Tech Tips
Jul 2, 2014 09:32 AM
devildocclem
2014-2024 Touring Models
Mar 29, 2014 05:20 PM
Jedx66
Jul 29, 2011 04:16 PM
vulhalla
Oct 9, 2007 12:54 PM
sketch
Jun 27, 2007 05:02 AM
