s@s 107 big bore
Old Aug 27, 2015 | 01:48 PM
Spalex06's Avatar
Spalex06
Stage III
Default s@s 107 big bore
Hey members. My name is Shaun. New to this forum. Any one have any input on s&s 107 big bore. It's for a 06 heritage with a 96 crank. Allready have 103 se hi comp Pistons Kendall Johnson heads and s&s 585 cams.
Old Aug 27, 2015 | 06:51 PM
ntraindavefl's Avatar
ntraindavefl
Why do all that for 4 cubes? Something wrong w current setup?
Old Aug 27, 2015 | 09:37 PM
baloot-boy's Avatar
baloot-boy
Probably not worth it and could spend that dough elsewhere on your bike. I'd post in the engine mechanical forum and hit up Scott at Hillside and Kirby at VeeTwin racing. Those guys really know their stuff.
Old Aug 27, 2015 | 09:54 PM
the wild hog's Avatar
the wild hog
Welcome and what you would end up spending, can not justify.
Old Aug 28, 2015 | 05:04 AM
misfitJason's Avatar
misfitJason
Did you buy the crank too because a stock 06 would be an 88 inch and have a different crank meaning you would need a s&s 95-98 inch kit
Old Aug 28, 2015 | 05:33 AM
Next In Line's Avatar
Next In Line
What is your riding style like?
Why are you unhappy with your current setup?
Old Aug 28, 2015 | 04:41 PM
Spalex06's Avatar
Spalex06
Stage III
Default s&s 107
. 94 hp 104 tq was hoping for better numbers
Old Aug 28, 2015 | 06:33 PM
ntraindavefl
Seems too low for that set up, maybe check your cranking pressure and go from there. You have bigger intake valve and flowed heads? should be at 110/110 at least even if TB is stock.
Old Aug 28, 2015 | 07:39 PM
Spalex06's Avatar
Spalex06
Stage III
Default 107 s&s
Yes. Kendall Johnson built those heads for my setup. Running easy start cams as well. Plus se 58 tb. Going to have a Indy take a look at it in a few weeks.
2-Piece
Aug 10, 2013 11:41 AM
dirtdobber
Mar 22, 2013 03:10 AM
2QuietBob
Feb 11, 2009 09:00 AM
swampking
Nov 3, 2007 05:05 PM
sugarbear
Jan 19, 2007 11:59 PM
