HELP....Having a Heritage issue!
Old Sep 29, 2015 | 05:53 PM
Mac117's Avatar
Mac117
Stage IV
Angry HELP....Having a Heritage issue!
I have a '98 Heritage Classic. My left turn signal has stopped working along with my speedometer and the rear fender light. Quickly losing it.....cannot isolate the problem. Any suggestions and help will be deeply appreciated......
Old Sep 29, 2015 | 06:12 PM
r1cochet's Avatar
r1cochet
I suspect too many changes from wiring on your '98 to my '14, but one thing that comes to mind is that I've heard of problems experienced with the ignition switch and/or the connections to the switch. i'd suggest to pull the console and check -
Old Sep 29, 2015 | 06:23 PM
Mac117's Avatar
Mac117
Stage IV
Thanks, I'll check that.
Old Sep 29, 2015 | 06:38 PM
73oldsman's Avatar
73oldsman
You may have 2 problems. Have you checked for trouble codes yet?
The turn signal and speedo problem sounds like the VSS or Speed Sensor. You can read up on this using the search function on the site here. Recently had the one went out on my 2000 Fatboy.
The rear fender light may be another problem, wiring or even a bulb.
Old Sep 29, 2015 | 06:41 PM
Mac117's Avatar
Mac117
Stage IV
I did remove the sensor and clean it, but no change. Maybe it is bad. Thanks for the insight!
Dynamike07
Aug 12, 2017 08:55 PM
SiggerTX
EVO
Jul 6, 2016 12:17 PM
davidparker530
Sep 10, 2015 06:22 PM
sandtrap10
Jul 1, 2013 02:51 PM
generallee01
Oct 30, 2007 09:36 AM
