new 103
Old Oct 13, 2015 | 03:13 AM
bklynbob's Avatar
bklynbob
The HO cams are nowhere near 255, actually a short duration 204 would be A better misnomer. The HO motor i believe also has another .3 point of compression. The ho cam specs:
.511 02/30 212
.511 43/10 233
12 degrees overlap as opposed to -8 for the previos cams,and .037 more lift(.044 less than se 255).
They respond very well to low restricion exhuast and professional tune. If you want more cam,look at the Andrews 48. Lower your gearing along with the above and you will really enjoy your ride....
Old Oct 13, 2015 | 03:40 AM
EagleRay's Avatar
EagleRay
I installed SE204 cams on my '14 103 Breakout. With a proper tune I was able to compensate the lack of torque in the lower rpm band while keeping the high hp output all the way through to 6000 rpm.
For more details and numbers check out my post in the dyno section
https://www.hdforums.com/forum/softa...l#post14355646
Old Oct 13, 2015 | 07:10 AM
Warp Factor's Avatar
Warp Factor
Originally Posted by Prot
Explain this in Heritage terms, when there is only 2.2 pound feet of torque more in the high output/new model.
That 2.2 pound difference is a single measurement at the torque peak. The difference may be greater elsewhere in the power band.
Old Oct 13, 2015 | 07:50 AM
Prot's Avatar
Prot
Possibly, but also look how much more torque the road King makes, and the road King is air cooled. I don't think that difference is because of the counterbalancers because prior to Rushmore, the output differences between a Softail and touring bike were minimal.
Old Oct 13, 2015 | 09:08 AM
fake's Avatar
fake
Originally Posted by lh4x4
A stock 103 bike like a 13 Road King going against a stock HO103 14 Road King will watch the 14 pull away from them with authority.
More fuel and air in is more power.
This is true. Before my Breakout, I had an 2011 103 Road Glide. My buddy has a 14 Street Glide (with the 103ho)
He could pull on me easily and both bikes were bone stock.
Old Oct 13, 2015 | 09:44 AM
SLV's Avatar
SLV
According to the published specs on the HD page, the compression is the same between the two. This is a Low Rider engine comparison
Also, almost every model has different torque ratings
One point of interest is the peak-torque RPM, which seems to be different for almost every model.
Bowhunter61
Dec 21, 2015 06:35 PM
Dixiemilker
Engine Mechanical Topics
11
Apr 8, 2015 08:00 PM
user 8373900
Apr 22, 2014 11:01 AM
FLYER
2014-2024 Touring Models
Mar 15, 2014 05:41 PM
2009blackpearle
Aug 23, 2009 07:42 PM
