...over the weekend on my 07 FXSTD. It wasnt as bad as I thought. I was afraid the factory O2 sensors could be seized into the pipe so I bought an O2 plug socket, after toying with it, the good old crescent wrench took them right off. Anyway, I got her installed and initialized. Started her up and wow, I can tell a difference. I rode her around for a bit, and heard some popping from the exhuast (HighRPM/Low Gear)then it went away. I didnt have time to put some miles on her since I was up late working on it, but I hope to run it more this week.
I have been loking at all the different options for a Delphi FI bike and the T-Max with auto tune looks like its not a heck of lot more money when you consider the added costs that all the other systems are going to have because they need to bedynoed to get them setup properly.
And they won't 'adjust' forweatheror higher altitudes than where and when they were setup at.
But I am curious about howmuch did it did cost andand whereyou got yours from. And if it will run all the standard systems, like the 6th gear indicator, security system, speedo, and clock functions.
I bought mine straight from Thunder-max for a little over $800. it took about 3 weeks to come in since they were making some changes. Everything works as far as thesecurity, speedo, and clock. I didnt see any changes with those issues, everything operated the same. There are some settings for the 6th gear indicator but when I received mine, those settingswere already made. It really was not that hard to install either. I think it was well worth the money, but I do need to ride it some more and see what happens. With the little bit of riding I did, I can tell a difference in just the way it sounds. I could tell right at start up. I did not get to check the 6th gear indicator though, didnt go fast enough but I will tonight.
I would appreciate it if you could post a more detailed assesment of the system after you get few miles on it.
Be interesting to see if a real world assement of it matches the advertizing hype.
You got it. I plan on doing some riding this week.
