Fatboy Lo - Cleaning the Rims
Old Nov 27, 2015 | 06:22 PM
HD_N00b's Avatar
HD_N00b
Default Fatboy Lo - Cleaning the Rims
Hi, all.
I have a 2013 Fatboy Lo in Black Denim with the black rims. Anyone have a good recommendation for cleaning the rims? Somehow a chemical was put on the rims that left permanent streaks.
Thank you,
J
Old Nov 27, 2015 | 07:21 PM
Tampa Fatboy's Avatar
Tampa Fatboy
Means the chemical was applied but not rinsed off/wiped off correctly.
Old Nov 27, 2015 | 07:39 PM
HD_N00b's Avatar
HD_N00b
But now how do I get it off? I tried soap and water and a mild cleanser, but neither worked.
Old Nov 27, 2015 | 08:02 PM
Tampa Fatboy
Looking at the photos, I'd re-paint them. Theres a good chance with todays technology a way around it. Good luk, brother.
Old Nov 27, 2015 | 08:05 PM
2500hdon37s's Avatar
2500hdon37s
Adam's polishes deep wheel cleaner. Its hands down the best wheel cleaner I've ever seen or used. Cleans up any type of wheel and wheel surfaces, I use it on my truck's chrome wheels and my bike's aluminum wheels. Knocks the road grime, brake dust, and anything else off very easy with minimal agitation.
but if some sort of chemical has stained or damaged the paint, its likely they're ruined, and will need to be refinished.
Old Nov 28, 2015 | 01:47 AM
stal94gt's Avatar
stal94gt
Those wheels are powder coated so carefull with what you use. Some chemicals can make it worse. If it were my bike I would pull the wheel try and sand them down to make an even color again. If that did not work I would strip them and powder coat them a solid black. I have my rear wheel re-coated solid black and I think it looks better
Old Nov 28, 2015 | 09:28 AM
HD_N00b's Avatar
HD_N00b
stal94gt,
I was wondering if they were powder coated. I'm sure that makes it more challenging/expensive to fix. Crap!
J
Old Nov 28, 2015 | 05:25 PM
Freak Show's Avatar
Freak Show
i use Kaboob bathroom cleaner. sprays on blue and dirt lifts up in the white foam. rinse then wipe with a soft cloth.
Old Nov 29, 2015 | 08:47 AM
swifty's Avatar
swifty
I too would try a polish something like meguiars Clear Coat Safe Polishing Compound.
worth a try. If that doesn't work I would find a place that does good powder coating and ask their opinion,, good luck and let us know how it turns out. swifty
Old Nov 29, 2015 | 10:21 AM
splattttttt's Avatar
splattttttt
have any of you ever use baking soda and water?
Usually a cup diluted with three or four gallons of water works wonders for removing oxidation and stains on most paints and metals. Raw or chromed. It can be made into a paste for use on more stubborn spots.
Then there's Zep heavy duty degreaser is also great. I spray this **** liberally on the entire bike. Scrub hard to reach area with a toilet bowl brush and rinse. Keep rust from reappearing permanently.
Try it. If you don't like it you can all take turns shitting on me. But I know it will work, so no worries.
Ilikeboost
May 22, 2016 07:07 PM
bigblock59
Sep 19, 2014 07:16 AM
peg20
May 1, 2013 05:15 PM
09B29
Dec 2, 2011 12:40 PM
Kojax
Sep 2, 2010 04:45 PM
