2011 softail - Rear Turn Sig Wiring Help
Old Jan 27, 2016 | 10:48 AM
LA_Dog's Avatar
LA_Dog
Originally Posted by izzyryder
so I'm going to take the 2 wires coming off the tailight, and connect ground to ground, and take the other single wire off to the taillight and connect it to the 2 other wires off the led? Will this give me the full range of functions on the new LED? If so, I think that would work fine, right?
yep that's what i am sayin- but test with a battery first - pretty easy.
positive of battery to running wire, negative of battery to ground wire. the running leds will be on.
then twist the brake and turn wires together and touch them to the battery positive. you'll see how it lights up if you wire it this way.
Old Jan 27, 2016 | 10:51 AM
izzyryder's Avatar
izzyryder
Awesome.. thank you sir.
So, now not to put a twist on things.. if I also have this.. is it something I should bother using?
http://www.harley-davidson.com/store...-11-6946306--1
Old Jan 27, 2016 | 10:56 AM
skid_pimp's Avatar
skid_pimp
Yes that, see me previous post
Old Jan 27, 2016 | 11:01 AM
izzyryder's Avatar
izzyryder
Sorry, thanks for helping.. didn't see your post refresh..
ok so..
ground --> ground
harley single wire off taillight --> led signals turn and brake wire combined
use the harley module.
Sound correct?
Old Jan 27, 2016 | 11:16 AM
LA_Dog's Avatar
LA_Dog
^^ yep that is good- go for it.
lateralus
Aug 7, 2018 09:56 PM
JemmyPaeg
Electrical/Lighting/Alarm
Apr 5, 2015 01:19 PM
NuttyKev
Sep 7, 2014 11:18 AM
broski24
Mar 16, 2012 02:55 PM
rounder
Mar 16, 2010 04:51 PM
