Do 2016 softail need better air cleaner
Old Jan 29, 2016 | 01:45 PM
Freak Show's Avatar
Freak Show
Originally Posted by LA_Dog
yeh Nomad is right it will be helpful along with pipes and tuner as a whole set. most important part is the tuner module considering the cam and getting rid of the overly lean factory fueling.
If you really want a significant increase in speed and acceleration, swap the belt drive pulleys for 30t front and 68t rear. it's the biggest bang for buck upgrade on a stock bike, especially one with a mild cam, since the belt pulley change shifts your rpm ranges slightly higher and into more of an optimal range for the cam.
nope, why do that. c'mon now, harley has been sticking to the same design for the past 100 years, why shouldn't you. lol
Old Jan 29, 2016 | 02:14 PM
DK Custom Products's Avatar
DK Custom Products
Sponsor
Originally Posted by fake
Anybody know is the Arlen Ness Big Sucker Stage 1 vents externally?
To externally vent the Arlen Ness Big Sucker you would need the DK Custom Products DIY Discrete Breather System. You can see in this image of an AN Big Sucker the stand-offs that are a part of the backplate have been drilled with an 11/32" drill bit and tapped with a 1/8" NPT Tap to vent the crankcase gasses to an external filter.
The DK Custom Products DIY Discrete Breather System comes with 6 feet of hose to give you maximum flexibility in positioning the washable breather filter. The drill and tap are available options for this DIY Kit should you need them to perform this upgrade to your Arlen Ness Big Sucker.
__________________
www.DKCustom.com
662-252-8828 Voice
662-420-4891 Text & Voice
Support@DKCustomProducts.com
roofcrash
May 19, 2016 02:34 AM
nashvegasmatt
May 31, 2014 03:48 PM
viperpit07
14
Dec 11, 2013 10:55 PM
chmartist
Sep 11, 2013 12:58 PM
Gator KStenz
Apr 20, 2009 02:38 PM
