05' Heritage Softail (detachable side plates)
Old May 13, 2007 | 05:05 PM
chango's Avatar
chango
Stage II
Default 05' Heritage Softail (detachable side plates)
I am looking for detachable sides plates for a Heritage Classic ...Do I need to buy a new set of bags?? AllI wantto do is remove the passenger back rest for in town riding..
Old May 14, 2007 | 06:33 PM
GADave's Avatar
GADave
Default RE: 05' Heritage Softail (detachable side plates)
In a word... no. You do need to get the docking hardware which will sit your stock bags out about 3/4" more than they are now. Otherwise the factory bags will attach the same way they do now.
Dave
Old May 15, 2007 | 12:22 AM
firebuckeye's Avatar
firebuckeye
On my 06 the bags set out but the docking kit did nothing with the bottom brace of the bag. So essentially it did not work because the bottom brace was 3/4" out from the stud it bolts to, near the passenger foot peg. Not sure if 05 is the same way. I talked with dealer and they had no idea how to remedy this and refunded me for the plates and docking kit. If any one has the solution I am curious to hear it....
Old May 15, 2007 | 10:09 AM
GADave's Avatar
GADave
ORIGINAL: firebuckeye
Solution to this is install the docking kit. Hang your bags on the bolts and start the nuts that hold the bags on. Put the bolt through the bottom bracket and start the cap nut. Tighten everything down. If you tighten the two nuts that hold the bag on before you put the bottom bolt though it may pull the bracket away - but there's enough flexibility in the bracket to just bolt it up.
Dave
Old May 16, 2007 | 01:47 PM
firebuckeye
I see.... so it kind of is hanging at an angle? Probably would never notice it. The dealership refunded me, and I will just leave it set up for 2 up riding I suppose. Thanks for the reply!
Brad
Old May 16, 2007 | 02:33 PM
Jim Dawson's Avatar
Jim Dawson
Another solution is the Bubba's Brakes detachable side plates and detachable bag kits. Everything is removable and the bags sit as close as stock.
Old May 16, 2007 | 09:31 PM
AK_Hog_Herder's Avatar
AK_Hog_Herder
ORIGINAL: GADave
Dave
The HD solution is the saddlebag relocation kit. It contains new offset brackets (stamped steel) to replace the stock rubber core ones.
HD Saddlebag Relocation Kit Part #90238-00.
Old May 17, 2007 | 01:53 AM
chango's Avatar
chango
Stage II
thanks
Old May 17, 2007 | 10:35 AM
BlessedHellride's Avatar
BlessedHellride
Go with aquick release kit for the bags while your at it. I'm installing a different set soon and will have my current kitavailable for cheap.
golfblues
Softail Parts
13
Dec 3, 2011 03:44 PM
tnhd06
Jan 2, 2010 08:53 PM
Strgzr
Apr 21, 2007 04:45 PM
HarleyWood
Jun 29, 2006 09:43 PM
OC
Jun 9, 2006 06:47 PM
