Hello everyone, I am trying to figure out why my 2013 Fatboy sometime on start-up it acts like its low on battery.This only happens on the first start-up afterover night. It does it more often then not but not always. Sometimes it does not do it (like you will see on the video). After the first start the bike will start great. I have no problems with hot starts either. The battery is 2 months old. Anyone has the same issue or what might be the issue?
Has it always done this, or is this a fairly new issue?
Original battery?
Do you start the engine with the transmission in neutral?
Try something simple and cheap first, clean all the battery cable connections (a small brass brush works great).
Remember, always disconnect the negative first, then the positive, and reconnect the positive first, then the negative.
I never start it in gear always in neutral. It is not a new issue. Battery cable are clean an tight. Battery voltage is 12.9. I have tried all types a starting sequences (kill switch first then ignition on, reverse that, start before pump completes pressurization, etc.) It seems to do it whenever it wants.
Sounds normal to me as well. 20/50 oil is standard HD oil weight.
You have compression releases, You must have done some work.
Two things come to mind:
1. Compression releases are not functioning as they should.
2. You have something draining down your battery over night.
You said you checked the cables, did you check tightness at both ends?
I also use dielectric grease on ALL of my connectors.
No work done on the bike it's all stock. All ends of cables tighten. Battery in my opinion is not the problem because you can continue to start the bike immediately after the first start and it starts perfect. I do agree it you that it might be the ACR. May they are dirty and sticking on the first start. I just don't know.
Doesn't sound too strange to me. How many cranking amps is your battery rated at? Seems most common is 310ish for our bikes. When I bought my bike, the battery in it was considerably less than 300 cca and I had some issues with cold starting. Replaced with a better battery and all good.
