Fatboy steering lock
Old Mar 30, 2016 | 05:05 PM
Gordon61's Avatar
Gordon61
Default Fatboy steering lock
Quick question if I may...
Some ****** tried to relieve me of my ride one night but only got as far as jamming the steering lock. I managed to work it loose and get going again but something is obviously twisted or mangled so I got a new lock.
Does anyone know just how much I need to drop the forks to get the tumbler out, I unfortunately don't have a proper lift so wonder if I can do this?
TIA
Gordon
Old Apr 3, 2016 | 12:07 PM
Gordon61's Avatar
Gordon61
quick bump to see if anyone has done this already
Old Apr 3, 2016 | 12:20 PM
Next In Line's Avatar
Next In Line
There should be a grub screw on the neck below the lock itself. Just remove that (2 or 2.5mm hex I think) and your lock should come right out.
Old Apr 3, 2016 | 12:44 PM
Gordon61's Avatar
Gordon61
Thanks, I got the grub screw and tried to pull it out already but on the 2014 Softails you have to drop the steering head to remove the lock (so the service manual says)
I was wondering if the lock will come out if you drop the steering head partially, or if indeed you have to remove it completely?
cheers
Old Apr 3, 2016 | 01:30 PM
Next In Line
I have a 2005 myself and it has been a very long time since I removed mine.
Looking at the parts manual online for the 2014 model, it has the same part numbers (45680-90 FORK LOCK & 45605-00A STEM & BRACKET ASSEMBLY, INCLUDING LOWER BEARING CONE) so I don't think anything has been changed.
Have you tried to remove it with the front end turned all the way to the left (locking position)? Also, with the grub screw removed, try rotating the whole assembly while pulling it out.
Old Apr 3, 2016 | 01:59 PM
Gordon61's Avatar
Gordon61
I'll give it another go but the book does say to drop the head
thanks
Old Jan 7, 2018 | 03:01 PM
Recuraz's Avatar
Recuraz
6th Gear
Did you ever find a solution? Thanks
Old Jan 7, 2018 | 03:17 PM
Gordon61's Avatar
Gordon61
had to drop it all of the way out
Incidentally, the damage was not just limited to the keyed lock pin either - the steering shaft was damaged as well.
Even when it was good you could turn the bars about a quarter of the way anyway, which became about a third after the damage ...I never bothered locking it after that.
Old Jan 8, 2018 | 10:39 AM
Recuraz's Avatar
Recuraz
6th Gear
Wow, mine isn't damaged, but I replaced my ignition switch and I wanted the keys to match. Sounds like it may not be worth the effort. Thank you for the information.
hal174
2014-2024 Touring Models
Mar 14, 2014 12:15 PM
br549A1
EVO
Mar 5, 2014 06:57 PM
chris26
General Topics/Tech Tips
Nov 15, 2012 11:08 PM
RidemyEVO
Jan 31, 2010 07:29 PM
alazlo
Shovelhead
Apr 19, 2006 11:15 AM
