180 tire on an '89 Softail
Old May 21, 2016 | 04:37 PM
nellis003's Avatar
nellis003
Default 180 tire on an '89 Softail
Hi all,
I'm doing a ground-up build of an 89 Softail, and would like to use a pair of late wheels I found for a good price. They're spoke chrome wheels, and the rear is a 180 with a cush drive belt pulley.
I found a wide swingarm for pretty cheap that will take the larger wheel, but I'm not sure about what else I need to do to make this work. I've built bikes before but always stayed bone stock. This is new ground for me.
So, do I need to offset the primary and transmission, or can I get away with shifting the wheel over to compensate? It's just an empty frame right now so it wouldn't be a big deal to add the parts, but I'd like to keep it as simple as possible.
Thanks,
Nick
Old May 21, 2016 | 11:09 PM
langwilliams's Avatar
langwilliams
you would probably get more info in the evo section. I put a 170 on my 93 softail using a 1" belt an it was a tight fit. to use those wheels you will probably need fork lowers an a swing arm to match the axle size. Here's a pic of my 170 with the stock swing arm:
Old May 23, 2016 | 05:52 AM
Tom84FXST's Avatar
Tom84FXST
For the bike to handle it's best, the wheel needs to be centered in the frame...this will require a trans/primary offset. Mount wheel in center of frame...then use a straight edge to see how much offset you need.
Old May 23, 2016 | 02:35 PM
nellis003's Avatar
nellis003
Tom,
Those pictures are a huge help, thanks. I have the swingarm getting powdercoated now, and when I get it back I'll do this.
Thanks again,
Nick
wharfcreek
Wheels/Tires
Jan 15, 2019 03:26 PM
M00kiE
Wheels/Tires
Sep 27, 2017 08:55 PM
pulser9
Oct 28, 2015 09:39 PM
langwilliams
EVO
13
Feb 18, 2012 07:43 AM
jhnmflr
Jun 3, 2006 02:22 PM
