Friday I noticed my rear brakes were slightly hanging and the pedal would stick. I would pull it up with my toe and it appeared to be ok till the next time. Today the first time I pressed the pedal there was no frigging rear brakes. Well I don't use much back brake but it sure is nice to have some when you need em. Trying to figure out if I just need to rebuild the master cylinder. Anyone have any ideas?
My ironhead used to do that then quit unless it was pumped 2 times. The fluid was fried. Was really old. Drained master and then bled brake til I got clean fluid out of the caliper. Worked fine after. If it's not low master could have a bad seal.
Two concurring replies within two minutes of each other. I believe I better listen. I am going to replace the fluid and bleed it. I will post when I find out if that was the problem. I hope it is because my sportsters rear brakes quit to. I put new forwards that were designed for a big twin on the Sport about three years ago with new fluid. It is alot less expensive to replace fluid rather than rebuild them AND replace the fluid so I will try that first.
Pull the caliper. My rear brakes went out up on the road one day. Lucky I was only few miles out from the house. Pulled the caliper and voila, keeper spring for the pads was bent allowing the pads to drop. Definitely change the fluid if it's nasty, I do this every 2-3 years.
Checked the fluid. It was full and clean. It also felt and smelled good. I was going to bleed but the damn bleeder was rounded off. I'll have to buy a new one so I can change it and bleed off the air when I can make to a parts store.
I'll look at that too. While I am foolng with the brakes I may as well pull the pads and check them and the springs too. Any time spent on brakes is time well spent.
Took out the stripped bleeder this evening with a pair of visegrips. I put my thumb over the hole and pumped the pedal and had pressure so the master cylinder is probably ok. I had to go to parts store, bought a new bleeder and replaced it. I'll bleed it tomorrow and post back if that's all it takes.
what year is your bike an what fluid does it take? If you bought it used someone before you may have mixed fluids, which is bad. If it's dot 5 it should be purple. If it's yellow it's old an needs to go.
