34 tooth pulley
Old May 20, 2007 | 01:19 AM
chopin's Avatar
chopin
Default 34 tooth pulley
For anyone interested...I installed the 34 t tranny pulley on my 06 deluxe. The aim was to lower the final drive for a more relaxed 55mph cruise. I am pleased to report this was very successful! Final drive now about 3.0 down from 3.15. Very similar to my 06 dyna with a six speed and final drive of 2.96.The gearing change is noticeable in the lower gears, but I like it that way...no adverse performance issues on my bike for the way I ride it ie...ssssllllloooooowwwww. Well worht the change for a fraction of the cost of a new six speed.
Old May 20, 2007 | 01:27 AM
airjoe's Avatar
airjoe
Default RE: 34 tooth pulley
I was thinking of doing the same on my 05 Fatboy.
What was the cost??
How about1st and 2nd gears?
Old May 20, 2007 | 07:37 PM
chopin's Avatar
chopin
Andrews pulley from J and P was about 175$. Labor about 400. I dont think that it is too complicated a task though and would bet anyone with some mechanical inclination to be able to do this easily ( I am not sure if there are some "special" tools needed). It beats 1700 for a tranny plus 1000 to install....at least for me it was. No problems with first or second....I ride solo and have a stage 1 on my deluxe. I like it so far. I have put 250 miles on it.
Old May 20, 2007 | 10:58 PM
pococj's Avatar
pococj
Special tools required to remove clutch stuff. Big ol' honkin' special socket/tool to remove sprocket nut.
Old May 21, 2007 | 12:10 AM
chopin's Avatar
chopin
Anyone know how to figure out exactly how much my speedo is off. I assume it is reading a slower speed than it really is going after the 34t sprocket.
Old May 22, 2007 | 11:03 PM
sniper's Avatar
sniper
Did you have to change the length of your belt or was there enough adjustment room on the rear axle?
Old May 28, 2007 | 01:05 PM
chopin's Avatar
chopin
no change of belt needed.
Old Aug 1, 2016 | 10:13 AM
jrv_hd's Avatar
jrv_hd
I just installed one on my 02 Heritage. love it 75 feels like 65 now
Old Aug 1, 2016 | 02:09 PM
Longplay's Avatar
Longplay
If you have a GPS or access to one you can borrow, it will give you a very accurate speed indication on longer straight roads. Set bike at 60 and let it stabilize. GPS speed will be your actual speed. Simple math will give you the ratio from that for all speeds.
Old Mar 29, 2019 | 02:10 PM
byersmtrco's Avatar
byersmtrco
Speedo error should be about 5 mph
So, if the speedometer is reading 70, your doing about 75.
07DYNAGLIDE
18
Jul 2, 2024 08:24 PM
Village Idiot™
Nov 18, 2011 07:23 AM
SPECIAL ED
Jan 9, 2011 12:07 PM
panheadmatman
EVO
Aug 1, 2010 02:41 PM
bagger76
Mar 15, 2010 10:12 AM
