Progress on mods.
Old Jul 24, 2016 | 10:49 AM
Duke 13's Avatar
Duke 13
Default Update
My dealer recommended that I order some 2016 Fatboy Risers so I purchased some on eBay for about $75 less than the price the dealer offered.
They said they should be a straight bolt-on.
If you're using the stock top clamp/speedo combo they're not. I discovered that they are a lot wider than the stock risers so I took them to a local machine shop and had them remove stock for the left and right sides of both risers.
I didn't have enough removed so I took them back for another pass.
We I got them home to mount I discovered that the clamping bolts from the Fatboy are larger and wouldn't go through the Breakout top clamp, so they are back at the machine shop to be opened up to accommodate the larger bolts.
Then they will be powder-coated gloss black. I should have them back by Monday.
I totaled everything up and even with the additional machining and powder-coating I'll still be about $40 under the delivered price of the Thunderbike Risers and they'll be a one-off riser.
I'll post picks when I get them back.
highwayman1224
Aug 14, 2016 08:52 PM
Brettfullthrottle
Softail Parts
Apr 11, 2015 04:41 PM
ryan9977
Jun 8, 2013 08:16 AM
gartec81
Sep 21, 2011 09:37 PM
gartec81
Sep 9, 2011 10:41 AM
