Lockable gas cap - lock broken!
Old Oct 26, 2016 | 10:07 PM
Clammy's Avatar
Clammy
Originally Posted by Yamaharley
Will it re engage if you put the key in. I have one and if I leave the key in the open position, it will just spin. I pop it out and twist it by hand while setting the key right.
I've been using it that way for a few months. Tonight, I went to put it back on after fueling up, and it just spun, without engaging the locking mechanism in order to tighten it. When I got home, I played around with it, and got it to work intermittently. I lubed it, and worked the lock back and forth. Sometimes, it works as normal. Other times, it just spins around without catching. I don't trust it at this point. I'd like to take it apart and see what's going on inside it, but I can't figure out how to do that without destroying it.
Cheers!
Old Oct 26, 2016 | 10:10 PM
Clammy's Avatar
Clammy
Originally Posted by QC
Does the mechanism need to be lubed with some Door-Ease or something similar?
After I got home, I lubed it with silicone spray, and it worked for a short while, then started spinning freely again. So I tired cable lube (graphite), and same result. Worked for a little while then began spinning again. If I play around with the key, working the lock back and forth, I can get it to work, but it's intermittent.
Cheers!
Old Oct 26, 2016 | 10:12 PM
Yamaharley's Avatar
Yamaharley
Cheers!
**** I better be careful filling up. Thanks for the heads up.
Old Oct 26, 2016 | 10:16 PM
Clammy's Avatar
Clammy
No worries. If it happens to you, try turning the key in the lock back and forth as far as it will go a few times. That seems to be the trick to getting it to work again, at least temporarily.
Cheers!
CVO SG
2014-2024 Touring Models
72
Dec 16, 2015 11:01 AM
Cobytur
Jul 31, 2013 09:48 AM
Gunny68
General Topics/Tech Tips
Jan 11, 2013 08:16 PM
Kojax
May 18, 2010 06:54 PM
fatbob
Jul 7, 2007 06:10 AM
