Alarm sounding while riding
Old Aug 12, 2016 | 08:45 AM
DaGooch3634's Avatar
DaGooch3634
5th Gear
Default Alarm sounding while riding
Have a 2001 FLSTFI fatboy FI. Just started an issue with my alarm sounding off while running and riding down the road. Intermittent at best with it coming on and off when it feels the need to. I am going to check my voltage on my battery. I have the older TSSM with push button fob. New battery in that this morning and still does the same thing. Once I get home I will check voltage on my battery. Bike does not seem to run any better or worse while this happens. Just annoying at this point knowing that it should not be happening. Any input would be appreciated. Thanks Gooch
Old Aug 12, 2016 | 11:55 AM
JustMike's Avatar
JustMike
Loose wire to the siren module or loose battery cable? Mines got a built-in backup battery. Goes off if power from the battery is cut.
Old Aug 12, 2016 | 12:47 PM
DaGooch3634
5th Gear
Thank you, I just checked the wires. They are still tight so I will check my voltage once I get home tonight.
Old Aug 12, 2016 | 10:21 PM
ILMFBL's Avatar
ILMFBL
Do you ride it like you stole it? Sorry, couldn't help myself.
Old Aug 12, 2016 | 10:25 PM
Next In Line's Avatar
Next In Line
Did you change out the 9v battery for the alarm?
Old Aug 13, 2016 | 08:14 AM
DaGooch3634
5th Gear
YES I do ride it like I stole it....lol
did not know it had a 9v in the alarm?
Old Aug 13, 2016 | 08:58 AM
Next In Line
http://www.harley-davidson.com/app-c...ts/-J01872.PDF
Old Aug 13, 2016 | 09:04 AM
DaGooch3634
5th Gear
thank you. I will change that while I am there. I also tested my battery and it is barely holding 11v on its own without ignition or acc on. So I will replace the battery and the 9v batt while I am there. Thanks
Old Aug 13, 2016 | 09:05 AM
Next In Line
Make sure that the 9v is a rechargeable one.
Old Aug 13, 2016 | 09:13 AM
DaGooch3634
5th Gear
Thanks for all the info. I appreciate it. Can't afford to let the stealership throw parts at it for it to do the same thing.
Bill Lisa Tardy
Aug 13, 2018 09:02 PM
Andy Titus
Aug 9, 2016 11:34 PM
Borracho
Aug 18, 2011 08:00 PM
FORDPOWER
Apr 2, 2010 04:51 AM
d59s67
Jun 23, 2007 10:51 AM
