I got a Fatboy lo and I park my bike in a shed daily. Shed has a little ramp..I ride front wheel in first and get out of the shed rear wheel out first. Now, I bought a motorcycle Dolly which will allow me to spin the bike around so I can leave the shed front wheel first. My question is will I bottom out now that I'm leaving front wheel first?
I got a Fatboy lo and I park my bike in a shed daily. I ride front wheel in first and get out of the shed rear wheel out first. Now, I bought a motorcycle Dolly which will allow me to spin the bike around so I can leave the shed front wheel first. My question is will I bottom out now that I'm leaving front wheel first?
Only one one way to find out! And if it does you can lessen the slope if necessary.
I only got a B in geometry but shouldn't it not matter? If you don't scrape going in or out front wheel first, shouldn't you not scrape going in and out going rear first?
Not necessarily only because it depends how low the frame is to the ground, how far the tire is from that lowest point on the frame (usually it's the lowest point of the frame just in front of the rear tire) versus the height of the transition, be it a ramp, speed bump or a curb. Most people could probably ride off (already on top of) a curb and not bottom the frame out but if you turn around and try to ride UP the curb, the rear portion of your frame will likely hang on the curb. Of course that doesn't mean you can just pop the clutch and ride off the next curb you see... as sure as you try that the footboards will hang up on the curb and you'll bust your nuts on the gas tank mounted key switch as well as do a really nice and some what graceful cartwheel over the handlebars and front fender and into the street. And when you jump up to see who all was watching, because you're so bad *** that you wanted to ride through the front yard rev'ing the damn engine up like a Mustang driver instead of just doing to three point turn in the driveway like most normal folks would do, the bike will STIIIIILL be standing straight up. Hung on the curb. Waiting for you. As if it's on the jiffy stand. I witnessed this one night... it was freaking awesome! We stood in the garage for another hour drinking beer with the guy all the while looking at the new yard art that he planted solidly I might add, on the curb.
OP, if you're using the same ramp, you will have more clearance coming OUT of the shed front wheel first than you do going IN the shed front wheel first. If it doesn't hang up going in you should have plenty of clearance coming out. But I would check it by easing it down the first time.
Agreed, it shouldn't make any difference on way or the other.
The lowest point on the motorcycle are the shocks and they of course are closer to the rear wheel. If you back the bike in, the rear wheel lifts the shocks
out of the way faster. If you go in front ways, the rear wheel doesn't get to do that, and only the front wheel (way up there,) lifts the shocks at a much gentler angle, and the shocks will scrape. It does matter.
Where the ramp meets the floor of the shed, the height of that peak, and the angle of the peak will be the same with the bike pointed in either direction.
If instead, one was going on or off a curb, the direction would matter.
It depends a little on the length of the ramp though. A super short ramp would behave more like a curb.
