Clutch issue
Old Nov 23, 2016 | 12:30 AM
Mike Diehl's Avatar
Mike Diehl
Stage I
Default Clutch issue
I have a 2011 fatboy, i changed the clutch handle. I did not touch any adjustments. If the bike is off and i engage the clutch and the bike is in gear it does not disengage. I can go threw the gears with out clutching. If the bike is running it shifts fine. Do i have a issue with it not running and not disengaging.
Old Nov 23, 2016 | 03:55 AM
misfitJason's Avatar
misfitJason
How in the heck did you change out the clutch handle without loosening the cable adjuster or clutch adjuster? You probably broke something
Old Nov 23, 2016 | 04:57 AM
Iceman24's Avatar
Iceman24
Even though you didn't make any cable changes, it's always recommended to do a clutch adjustment. It doesn't take much movement on a cable to get things out-of-synch. IMO...loosen the adjuster & reset/set the clutch cable properly. If that doesn't work, you might've popped something loose and need to dig deeper. Good luck!
Old Nov 23, 2016 | 06:54 AM
S.D.M.F's Avatar
S.D.M.F
Might have dislodged the ***** in the coupling and ramp assembly.
thanoskazakos
Aug 11, 2018 08:48 AM
rick775472
Jul 5, 2015 09:08 PM
rdondes
Oct 23, 2013 08:16 PM
danny54
Oct 21, 2012 02:24 PM
CT-Bagger
Oct 7, 2012 09:53 PM
