ghost codes
Old Dec 20, 2016 | 03:30 PM
riddenchoppedsofttail's Avatar
6th Gear
Default ghost codes
Check engine goes on while riding occasionally then speedo freezes and the odometer goes blank along with bike running liek garbage.I pull clutch in and turn bike off then fire back up while moving and it goes backto normal.No codes. Any ideas?
Kevin
Old Dec 20, 2016 | 03:31 PM
rquest's Avatar
rquest
sensor
Old Dec 20, 2016 | 03:33 PM
6th Gear
Originally Posted by rquest
sensor
which? TPS? It almost seems like a short.
Old Dec 20, 2016 | 03:44 PM
racerkvn's Avatar
racerkvn
Sounds exactly like the main switch to me. Very common symptoms. Take it apart and clean all the contacts (you may even want to swap the contacts from the "ACC" position to the "IGN" position).
Old Dec 20, 2016 | 03:46 PM
6th Gear
I will deff look into that. Thank you for your time
Old Dec 20, 2016 | 04:04 PM
racerkvn's Avatar
racerkvn
That switch has costed many a owner alot of money and run around chasing sensors and wiring.
Once you get the switch off you'll see the snap ring on the back side, just take that off and you'll have it opened up. I cleaned all the springs and contacts individually and then swapped the ACC contact/spring to the IGN position. Put a little dab of dielectric grease on them and put it back together. It's an easy project and doesn't take that long. I'm going to make that part of my "winter maintenance" from now on (take it apart and clean it).
foxhd
Electrical/Lighting/Alarm
Sep 18, 2015 10:21 AM
Texas_Rider11B
Jan 16, 2015 10:55 PM
05sporty8837879
Aug 13, 2013 07:55 PM
EricM
Jul 5, 2008 08:37 PM
rustydiver
Jun 21, 2006 08:59 PM
