Rocker-C Build
Old Apr 9, 2017 | 09:12 PM
  #41
Sarah93003's Avatar
Sarah93003
Originally Posted by 907_rocker
Was running super hot, burned a hole in my jeans from the pipes. Seemed like every time I do something I need to put it back on the dyno. I'd rather just adjust it when needed and I like the sound of the carb way better.
I've lost 4-5 pairs of jeans due to my pipes. In addition to keeping my leg further out on the footpeg, I'm planning to ceramic coat my pipes when the budget allows. You can coat them inside and out and reduce the heat considerably.
Old Apr 9, 2017 | 09:36 PM
  #42
907_rocker's Avatar
907_rocker
6th Gear
Well when I had my 2-1 I had 0 issues. I upgraded my intake, and added a fuel pack, 0 issues. Changed the pipes and it wasn't so bad until it hit the dyno. It got progressivly worse each ride until I almost had to get off it at a red light in 70 degree weather. The pipes are are more away thank the old Vance and Hines were, that kinda heat is way too much. Pipes are coated and wrapped.
Old Apr 9, 2017 | 10:10 PM
  #43
skid_pimp's Avatar
skid_pimp
Just from looking at it, those pipes will probably always be a bit hotter than more typical pipes, and weather you stay will fuel injection or go carb, besides coating and wrapping, the only way to cool them down more at a stop, is turn it off, or dump a fair bit more fuel in there, which can be easily done with a tuner, or a carb.
Old Apr 9, 2017 | 10:45 PM
  #44
907_rocker's Avatar
907_rocker
6th Gear
It was tuned, I just added those bends to give the pipes more length to help. It had 100% fuel dump in each cylinder also, hopefully the carb will help. I just like the fact I'm going away from many components to just a few. It's basically going to be wired and run the same as a big dog would.
Old Apr 9, 2017 | 10:51 PM
  #45
skid_pimp's Avatar
skid_pimp
I hope it helps ya.
Old May 6, 2017 | 02:33 AM
  #46
j33ptj's Avatar
j33ptj
SNeak peek from Ridewright wheels of my new wheels....
Now just waiting for shippinggggg.....
Happy though!
Old Jun 12, 2017 | 01:54 AM
  #47
j33ptj's Avatar
j33ptj
Default Belt cover progress
Got some pictures to drool over from Martil engraving...
Totally awesome!
Old Jun 12, 2017 | 07:23 PM
  #48
Sarah93003's Avatar
Sarah93003
Very nice!!
Old Sep 4, 2017 | 02:55 AM
  #49
j33ptj's Avatar
j33ptj
Since the rocker housings are of the engine and I had access to the rockers, decided to install the Rock outs.
Easy job and hopefully a bit less rattling!!! TIme wil tell...
RJ
http://www.rockout.biz
Old Sep 12, 2017 | 07:45 AM
  #50
j33ptj's Avatar
j33ptj
Default Sneek peek
Sneek of the carved areas that are to go on my bike...
Robert
