Rocker-C Build
Old Oct 30, 2017 | 12:35 AM
  #71
LRZ's Avatar
LRZ
Originally Posted by j33ptj
Decided to show my "build-progress", all started in 2009 where I installed a bunch of stuff to replace some of the dreadful HD.
First steps where some chrome upgrades and additions:
Grips and pegs
Shifter, brake and gear-stick levers for Bullet style
Installed the Heartland conversion EZ_R with custom-covered by Danny Gray seat
Lowering bolts for the suspension
Added their mirrors and indicator lights
TD-products license plate holder
HD Chin spoiler
Chrome belt cover
Chrome brake calipers
Vance and Hines 2-2 w/Big city queit baffles
HD handlebars
HD "chrome" control lines
Tassels on the break/clutch levers from Capt'n Itch
So everything was fine.... (or was it?)
Soon the rear suspension was replaced with Shotgun Shocks' airride (what a great improvement, I was lucky my kidneys survived the lowering bolts) and the front was lowered somewhat with progressive springs also added were:
A 21" replica front wheel from Paul Yaffe
Heartland 21" front fender
a chrome 18x8" chrome rear wheel
MotoX oil tank
So all happy again, right?
no... added a new handlebar (local made mini ape) and the front fairing. Also replaced the short rear fender with a longer one from Heartland.
But then I saw the engraving on ink83's project and that kicked me off again.
So the rocker covers and housings, the cam cover and a few bits came of and are now with Catur in Indonesia for engraving. In the mean time getting the following done:
Primo Open Belt drive (side covers with Catur for Engraving)
Footboards custom made by TD Products
parts to made out of brass: (pegs and grips amongst others)
lining some stuff up for copperplating
will start adding pictures of stuff as they come back to me!
Robert
ever raise the tank?
Old Oct 30, 2017 | 12:46 AM
  #72
LRZ's Avatar
LRZ
I guess so. 2". I just put a 3" on mine and haven't used it yet (powdercoat).
Did you notice any noticeable changes to how the gas gauge works. ?
Wondered if screwed myself on gas full ups.
Old Oct 30, 2017 | 01:07 AM
  #73
LRZ's Avatar
LRZ
We had some great weather and the bike was running so went out a took some pictures of the current "final" result!!
Robert
killer
Old Oct 30, 2017 | 02:08 AM
  #74
skid_pimp's Avatar
skid_pimp
The gauge will fall to empty faster with a tank lift, as well as the low fuel light will come on sooner. I have not noticed any loss of usable fuel quantities personally, so know your mileage per tank and all is well.
Old Oct 30, 2017 | 03:58 AM
  #75
j33ptj's Avatar
j33ptj
Yes, 2". the gauge showed m/t earlier than with out the tank lift. I do not think the range has changed, but still need to discover that. I once got 300km out of a tank, but filled it with 19l. Was basically flying on vapour!!
Still need to check if there would be an impact on the range....
Old Oct 30, 2017 | 09:28 AM
  #76
Rocker B's Avatar
Rocker B
Yes, the gauge will be off, and you'll get a few less miles per tank. I have a 2" lift and get about 15-20 miles less per tank than before. The fuel cross-over line is in the front of the tank, so when it's raised, some fuel gets trapped on the right side of the tank when the level gets below the cross-over hole. It's than a 1/2 gal. with my 2" lift, but I would think a 3" lift might trap a little more.
Old Oct 30, 2017 | 05:54 PM
  #77
skid_pimp's Avatar
skid_pimp
Looking at the height of the center ridge on the tank, I would venture a guess that a 3" tank lift would trap less fuel than a 2" does.
Old Oct 30, 2017 | 06:44 PM
  #78
Rocker B's Avatar
Rocker B
I just looked at mine, and I think your right skid, a 3" should let more fuel get over to the left side, at the rear of the tank....I didn't think of that.
My above post should have read "less" than 1/2 gal. is getting trapped with my 2" lift, so the decrease in miles per tank full with a 3" lift vs. the stock set up should be minimal.
Old Mar 13, 2018 | 07:00 AM
  #79
j33ptj's Avatar
j33ptj
Default Phone Mount
Installed a phone mount by Quadlock for the use of my IPhone as Navigation system.
Also working on a bobber seat.... more to follow on that later, hahahaha!
Robert
Attached Thumbnails Rocker-C Build-img_6340.jpg   Rocker-C Build-img_e6341.jpg
Old Mar 13, 2018 | 11:42 PM
  #80
Sarah93003's Avatar
Sarah93003
How does it do going down the road?
