Brake fluid
Old Mar 10, 2017 | 07:35 PM
balloo's Avatar
balloo
Default Brake fluid
I am having the brake fluid flushed on my 2008 Heritage.
Dealer said would use DOT-5.
I started reading about brake fluid and got so confused, I gave up.
Is DOT-5 the proper one?
Thanks
Old Mar 10, 2017 | 07:42 PM
hattitude's Avatar
hattitude
Thanks
Probably is.... it usually says right on your master cylinder cap. Of course if it's a used bike, heaven only knows what a prior owner has done.
Harley used DOT 5 for awhile. I have it in my '03 Heritage and DOT 4 in my '12 Limited.
DOT 5 is actually superior to DOT 4, but it does not play well with ABS systems. When Harley went to ABS brakes, they had to go backwards to DOT 4.
I lose track of the timing of all the changes, but if your Heritage does not have ABS brakes, it's a good bet it has DOT 5 brake fluid...
Edit: I just did some reading. It appears HD went to ABS on police service in '05 and for '08 the touring and Vrods got ABS... it's probable that when they started using ABS in '05 or '08, they went back to DOT 4 for all bikes to keep it simple... hopefully your dealer will know for sure.
If you ever want to know for sure, here is a simple test: use a clean syringe to remove some fluid from your master cylinder. A bottle cap's worth is more than enough. Now take your choice of brake fluid, and just add a drop to the amount taken from your master cylinder. If it mixes, your master cylinder is compatible with whatever type you tested with. If it stays separate (like a drop of oil in water) they are not compatible....
Old Mar 10, 2017 | 07:56 PM
misfitJason's Avatar
misfitJason
It's probably dot 4. Most newer bikes are
Old Mar 10, 2017 | 09:30 PM
langwilliams's Avatar
langwilliams
my 02 v rod was dot 5 but 05 electra glide was dot 4....I would not go to 5 with just a flush, I would think a disassembly/clean/new O rings would be needed for the master cyl an calipers.
Old Mar 10, 2017 | 09:38 PM
Bluraven's Avatar
Bluraven
My 09 Heritage per the owner's manual uses DOT 4.
I didn't look it up in my service manual but I'm sure it states the same.
If the dealer is doing the flush and they get it wrong they will just have to fix it.
Old Mar 10, 2017 | 10:58 PM
lh4x4's Avatar
lh4x4
I have a few older bikes that used DOT five. But not wanting to have two different kinds I changed them to DOT 4. Drain thoroughly using a vacuum bleeder pump then fill and flush two to three times.
DOT five is better for racing as it has a high boiling temperature. DOT 4 does acquire moisture over time and should be flushed at least every two years.
I don't know the year that they changed but my 10's were Dot 4. My 2000, 3 and 5 were Dot 5.
Old Mar 11, 2017 | 03:33 AM
j_bee's Avatar
j_bee
If your 2008 softail has standard brakes then Dot 4 is the correct fluid, not Dot 5.
It may have been a slip of the tongue that they said Dot 5 but definitely worth confirming what they've used.
Old Mar 11, 2017 | 03:41 PM
balloo's Avatar
balloo
THANK YOU EVERYONE....
My bike goes in on Tuesday, and their quote showed DOT 5.....
I found my owners manual, AND it shows DOT 4.
Glad all of you helped me get this correct.
I love this forum..
Cheers,
Old Mar 11, 2017 | 04:01 PM
Bone Doc's Avatar
Bone Doc
So here's the question of the day which is purely hypothetical at this time.
Although the dealer's quote stated DOT 5 brake fluid, would they check the master cylinder cover or the specs for the OP's year and model bike and put in the correct fluid, DOT 4?
You can only hope so. It would be a rookie mistake if they put the wrong fluid in.
Old Mar 11, 2017 | 06:53 PM
lh4x4's Avatar
lh4x4
When DOT 5 and 4 are mixed they almost instantly turn into a thick rubbery mass and the brakes will not function. Hard to get the lines cleaned out.
blue bronco
Dec 20, 2018 06:08 AM
hardheaded
Jul 9, 2018 06:13 AM
jwnusbaum
May 29, 2017 05:38 AM
Choopy
May 23, 2015 12:33 AM
BOSOXFan
Jan 26, 2014 08:22 AM
